Page 7 of 17 FirstFirst ... 56789 ... LastLast
Results 91 to 105 of 244
Thread: 1001 ways to use LW and Blender together
  1. #91
    nowhere
    241
    in the matter of fluids .I want to show you a technical test i did in 2008 for a short film when i work for chamán studios.This is modeled and animated in Lightwave,fluids calculated in blender and rendered back in Lw (lw 9.5).
    Basically shows the solution that we found for a typical scenario in the short film: an rigid and dinamic surface in constant collision with a fluid. Sounds common ,but not all the cheap solutions can manage this, even at this time.
    Attached Files Attached Files
    Carlos Puebla
    //TD 3d Character Artist.
    ncpuebla (arroba) gmail dot com
  2. #92
    Any of you fluid peeps know why my fluid particles might explode like this?
    http://screencast.com/t/BvrdfFkLvb
    BTW Carlos, that's pretty cool.
    ~~Phil Nolan
  3. #93
    nice clip lightmann :]
  4. #94
    Jun 2005
    Reading UK
    3,137
    Not too sure, but it looks like a high number. Did you try reducing generate to 1? I remember reading somewhere to treat the particle generation with caution and them being scene and resolution dependent.
    I guess it back to trial and error. There seems to be very little in the way of information on the fluids in Blender - the best I've seen is the CMI VFX video, but it doesn't cover any of the exotic stuff like control fluids or time reversal etc...
    i7 X3930/32GB/Quadro 4000
  5. #95
    Turns out it was related to subdivisions for some reason. If I have it set to 3 it explodes, 1 or 2 is fine.
    My problem now is that my fluid splashes, then some of it lands on this invisible "shelf" in mid air.
    Video: http://screencast.com/t/i3GKOxrx4
    ~~Phil Nolan
  6. #96
    Jun 2005
    Reading UK
    3,137
    Worth knowing about! Cheers
    Do you need to use subD though? - LW can do that part when you import
  7. #97
    Quote Originally Posted by Philbert View Post
    what happens if you change the resolution of the fluids to 200 ?
    it must be a bug... of some sort...
  8. #98
    Well it takes a couple hours to bake so I'll have to wait to find out. lol I did bake it pretty high over night last night and I think I had the same result.
    ~~Phil Nolan
  9. #99
    heh... :]
    well, i made a post here... :]
    http://blenderartists.org/forum/foru...nd-Simulations
    (takes a while for my post to show, apparently all new posts go through a moderator first)
    "yiiikes!" :0
  10. #100
    Yeah I posted there too, still waiting for mine to show as well.
    ~~Phil Nolan
  11. #101
    OK a little quicker than I thought. It looks nice but I srtill have the "shelf" issue.
    ~~Phil Nolan
  12. #102
    Does anyone know how to import the fluid particles with the Splotchdog plugin? Chris's tutorial over there doesn't really explain that.
    BTW I think I meant to include this link in the above post. My shelf issue seems to have fixed itself.
    http://www.youtube.com/watch?v=zKxVz6XBSbM
    ~~Phil Nolan
  13. #103
    Jun 2005
    Reading UK
    3,137
    I think your meant to use the particle import plugin in the deform tab.
  14. #104
    Thanks I emailed Chris and got that info, I never would have looked there though. Now I just have to stop the fluid mesh from being upside down. It's easy enough to flip it, but the particles were correct so if I flip the mesh, now the particles will be upside down.
    ~~Phil Nolan
  15. #105
    Jun 2005
    Reading UK
    3,137
    can the particles be loaded onto a seperate null?
