Results 1 to 9 of 9
Thread: Vue 9 install problem: Installer not finding Lightwave 10 install?
    Oct 2007
    Scotland UK
    16
    Recently got around to upgrading to Vue9 Xtream, trying to installing it I have a problem;
    During install of the XtremePlugin I pointed it to the LW10 install directory C:\Program Files\NewTek\LightWave10.0\bin, but the installer stops saying it cannot find the lightwave installation!
    Emailed E-on about this but no reply so far, also cant find anything similar in their support forums specific for Lightwave integration.
    At the moment I've installed Vue as standalone and updated to the latest version.
    http://www.e-onsoftware.com/support/...&id=1289824487
    I had hoped that could get LW and Vue talking?
    Sadly no though, installing the Xtream plugin STILL doesn't find my LW10 install....grrrr.
    Could it be a windows permissions thing?
    Any other ideas?
    Lightwave 10 Build 2067
    Vue 9 Build 5691
    Should be ok?
    Thanks.
    *EDIT*
    Just to check, installed the PLE version of Vue and the install found LW10 no problem.
    Los Angeles
    7,130
    Just a thought but can you install to 9.6 and then just copy the vue plug-ins to 10?
    Oct 2007
    Scotland UK
    16
    Quote Originally Posted by Greenlaw View Post
    Good idea.
    I'll try that.
    Heffalump
    Away
    3,897
    The issue is that NT rearranged the program folder structure just before release, and totally failed to communicate this to third parties.
    You should be able to persuade Vue 9.0 to install by renaming 'support' to 'SharedSupport' and placing copies of the LW executables in to the main LW folder - the installer does not expect to find the programs in the 'bin' folder.
    e-on was informed about it, but only was able to fix this in a post-release update for Vue 9.0. Vue 9.5 will handle this with no problem.
    Inactive.
    Oct 2007
    Scotland UK
    16
    Thanks Phil,
    I tried that and still the same...
    Still to reinstall a temp copy of 9.6 and try repointing the plugin to 10 during install.
    Heffalump
    Away
    3,897
    Raise a support ticket with e-on, I'd suggest. Last time I tried to use the 9.6 plugin with 10.0 on Mac, I encountered all kinds of problems. I think that they are compiled against the respective SDKs.
    Inactive.
    Oct 2007
    Scotland UK
    16
    Will do Phil.
    Thanks.
    Heffalump
    Away
    3,897
    If you recently upgraded, you probably got 9.5 under the 30 day bundled maintenance and I'd recommend deploying that upgraded version rather than 9.0. It will work with the LW10 folder structure and brings various improvements.
    For 9.0 specifically, an alternative approach is to install xStream as-is, including the LW 9.5/9.6 plugin if you wish. Then visit e-on's updates page for xStream 9.0. Scroll down on there until you see the updated standalone plugin installers - they are not obvious because e-on didn't put them in the table at the top of the page.
    The changelog for these cites Autodesk 2012 products, but the refreshed installers also gain the ability to handle the new LW10 folder structure.
    I hope that helps.
    Inactive.
    Super Member ben martin's Avatar
    Jun 2003
    Portugal
    821
    Another solution is to install LW10 in the expected path C:/.......
    Then, the Xstream installer will recognize LW10.
