Results 1 to 15 of 21
Thread: VPR_vs_Render
    VPR_vs_Render
    Hi guys.
    I am working on texturing and shading a model, can someone help me understand why the vpr render is so different to the f9 render?
    This only happens when I use the node shader material simple skin, I tweak, getting the look I want which is updating in vpr just great, but then my render is nothing like it.
    Trevor Smith
    Gallery
    Axes grinder- Dongle #99
    Seattle
    14,727
    Because it's a previewer, not a final renderer?
    Praise to Buddha! #resist
    Simple skin is not compatible with VPR, and neither are most of the SSS shader nodes, or anything which calls a pre-compute function before the renderer. This is no different to Fprime, which also can't use any shader which calls a pre-pass before the render.
    NT are aware of this and are working on improved shaders and improvements to the VPR system.
    NB: You should report this in the HC area as discussions about specific HC issues aren't supposed to be made public. Suffice it to say a lot of the new functions in LW 10.x are still in beta.
    Thanks Tobian.
    Trevor Smith
    Gallery
    To me this looks more like ColorSpace settings difference, Did you save your Render as Linear or sRGB ? VPR looks like sRGB and render like Linear.
    cheers
    RAM-Studio
    You should check out a new feature in LW 10.+ you will really like, if you haven't already download the latest build, and watched the preview vid, you should!
    Thanks Lewis, the colour space settings are the same, both are linear.
    It just seems to be any material node thats different in vpr and render, if I turn off the material node both vpr and render are identical.
    Trevor Smith
    Gallery
    Yep that sounds like what I thought. The shader is made up of a diffuse+reflection+spec+sss element, and the difference is all of that - the sss part, which VPR can't do. Hopefully the latest news should please you!
    Another reason that renders in VPR might look differently is beause VPR uses a draft mode by default which renders faster but doesn't do as full a job as normal. You can check it off in the VPR options found in the top right hand corner of the window.
    Super Member JonW's Avatar
    Jul 2007
    Sydney Australia
    2,235
    VPR is great but it is only a preview, if you have a stack of polys it's a bit painful even with a pair of W5580 CPUs. So a small render with low AA is almost as quick.
    Having said that for a bit of fun with monitor real estate!.....
    14,890
    Have I been mistaken the VPR promotion wrong along the line?
    As I percieved it..I thought it should and could render almost anything, with emphasis of not being a previewer like other software or fprime, but what you see is a low res iteration process
    that is as the final renderer, except post processing to match that as of the final render?
    Ivé recently been testing dielectric materials, only to found out that there
    seem to bee quite big differences in how glass is rendered, that is a bit unfortunate since glass is a such delicate material to tweak, and not matching the final renderer, makes it less useful to use the vpr at all for glass tweaking.
    I love the VPR for many other stuff thou, but I was just a little dissapointed that glass dielectric doesn´t seem to render properly to match that of final render.
    The conductor material seems okay thou, but who knows if it suddenly appears completly different render in the final render once you tweaked it in vpr?
    Michael
    Guys. I think this is pushing the nature of the NDA somewhat. Perhaps a mod can move this thread into the HC area?
    Quote Originally Posted by Tobian View Post
    How ? Isn't Trevor using LW10 released in DEC 2010 and Simpleskin node+VPR? What's under NDA there in LW which is released 5 months ago ?
    I don't see him showing 10.x layout or saying which version is this?
    RAM-Studio
    Yes but like I said the work on VPR is ongoing and there are certain *things* In LW 10.1 which aren't properly public yet, which will help him out. I don't know how to make it more obvious than saying it Lewis, which I can't, obviously.
    I think that VPR does a lot and it does it very well. Dont forget that this is only the first release.
    There are some smaller issues, most of them are due to the legacy of some features, which were never designed with something like VPR in mind (some nodes that use preprocessing come to my mind here).
    I guess that NT will improve on these issues in coming releases and that more things will work with VPR in the future.
    This is only the very first version after all.
    IMHO, it actually does more than I would expect from it.
    Yes, my Avatar shows a volume rendering...
    VoluMedic Creative Edition only USD 299 !
    www.volumedic.com
