Thread: Fast Motion or Stop Motion?
    Oct 2009
    Yoder, Kansas
    51
    I will film 60 drum sets being set up and will shoot from the ceiling of the auditorium strait down. I could let the camera run for 2 to 4 hours and then speed portions of it up. But am wondering if there are any other ideas out there on how best to get a fast motion effect. Being the first time to do this, am wondering what tips others might have. (I use the Vixio H100).
    Sep 2009
    Caribbean
    484
    I had real success in doing time-lapse photography by using a Canon EOS camera with a remote clicker plugged in. The clicker was a homebuilt 9V DC power supply with a resistor-capacitor time delay, and acontact closure to discharge the capacitor and also click the shutter. Vary the voltage to the capacitor and you get different times. Mine was ten minutes between clicks. With the right fixed-aperture settings on th a camera and a big enough chip, you take the JPGs later into the timeline & wham, it looks awesome!
    I have never bothered researching doing this with a video camera or even if there are settings in video cameras for slow framerates.
    If it's only a few hours, record it, transfer it, and speed it up to 2000% in SpeedEdit.
    If it's more, you need a bigger hard drive and a longer transfer.
    time lapse
    The VT has capture and builds an avi using time lapse capture.
    The settings are set by the user.
    Pete
    Pete Draves
    CV Productions
    Oak Creek, WI
    [email protected]
    Oct 2009
    Yoder, Kansas
    51
    Thanks Mutley. I ended up taking a pic with the Canon HF100 at intervals and worked great. There are parts that I am speeding up to 1000% but it stutters on playback. Is this due to lack of RAM? ALso, will it be smooth once rendered out and burned to DVD?
    Oct 2009
    Boise, ID
    160
    Quote Originally Posted by Pete Draves View Post
    Pete
    Does the SE in the 850 have this option?
    Sep 2009
    Caribbean
    484
    "Is this due to lack of RAM? ALso, will it be smooth once rendered out and burned to DVD? "
    Probably, or disk access speed.
    Render a low-res WMV file & watch it, or an MPEG2 file or whatever. Then you'll know what it'll look like when you burn a DVD.
