Thread: Extruding polygon gives disconnected shapes
    Mar 2010
    Wellington
    25
    Hi
    I extruded a poly from the side of a box and tried to sub-d it with tab. It ended up as two disconnected objects. I got around this by merging the vertices at automatic range, but in the end while changing to sub-d, got some unwanted polygons at the point where the merge occurred. Also, I had to flip the selected poly before applying extrude, otherwise the newly extruded were inside-out.
    Is this the right way to do it? How can go about extruding without having to worry about merging and excess polygons and flipped normals?
    Thanks very much.
    Super Member ramccombe's Avatar
    Lemon Grove, Ca.
    387
    Try Multishift
    I use Multishift or Extend and Move/Rotate etc. You are correct Extrude behaves as you describe. Hope this helps
    Richard .......
    1 Ghz TI PowerBook 10.4.11
    Dual 1 Ghz Tower 10.4.11
    Axes grinder- Dongle #99
    Seattle
    14,740
    Use EXTEND(ER), not Extrude.
    Extrude is generally better thought of as a tool for working on 2d polys, IMO.
    Praise to Buddha! #resist
    Mar 2010
    Wellington
    25
    Thanks guys. I had tried extender plus before, but it dint seem to be working. Did a good search and found out that each time you hit 'e' an additional poly is generated there, that can then be moved around. I was looking at the numeric panel and thinking that it wasn't working when nothing came up!
    Seattle
    14,740
    Yeah, it's very slick, but just clikin' the button looks like nothing happened. There's a couple tools like that: until someone tells you 'the secret' it's hard to know what all the excitement is about.
    In case you don't know: you can hit the hotkey for "Extend" without dropping the Move tool, so it is VERY interactive.
    Mar 2010
    Wellington
    25
    Figured that out when I finally got it working. Thank you
