Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 99
Thread: The Hobbit Movie being filmed at 48 FPS
  1. #46
    eye kan kode gud jrandom's Avatar
    Dec 2009
    Seattle, WA
    1,143
    Quote Originally Posted by RudySchneider View Post
    Well, there is the possibility I'm all wet. What about the refresh rate of you monitor? My HP w2558hc, for instance, refreshes at either 60Hz or 75Hz, depending on the screen resolution.
    It was a fancy 120Hz CRT monitor so I could use it with LCD shutter glasses (which I eventually sat on and broke).
  2. #47
    Super Member Hieron's Avatar
    Aug 2006
    Netherlands
    1,685
    Can't believe there is a 60hz "uncanny valley" while 48 and 75 being fine, it would have been well documented. Quick tests an a random monitor wouldn't compare to efforts done on commercial systems for live venues.
    60hz is eerily close to electronic issues due to external or internal factors of the pc, in the dark or not. Not sure how something in human vision would have issues with a specific framerate like that.
    Normal uncanny valley is well documented and easily explainable.
  3. #48
    Dec 2009
    Seattle, WA
    1,143
    It may very well have been subjective, but to my eyes there is a noticeable quality drop at 60fps. No idea what causes that.
  4. #49
    Banned OnlineRender's Avatar
    Dec 2008
    Glasgow , Scotland , UK
    6,375
    Quote Originally Posted by jrandom View Post
    probably not a drop in quality more to do with your eyes not processing it fast enough causing it to look worse / blurred , just a thought !
  5. #50
    Dec 2009
    Seattle, WA
    1,143
    Quote Originally Posted by OnlineRender View Post
    That wouldn't explain why 75fps looked so beautiful. It was a particle system of bouncing balls done in 3DS Max sometime around the year 2000 or early 2001.
    Maybe it's the framerate combined with in-frame motion blur that hits a bad spot at 60fps. At 24-48 fps you get more blur but it works well at those framerates. At 75fps you get less in-frame motion blur but more "actual" motion blur via your eyes, resulting in what I can only describe as "beautifully fluid" motion.
    (It may have also been the fact that I was rendering at standard definition -- maybe 60fps works better at full HD and higher resolutions?)
    I'm a total dunce at lightwave animation since I've been mainly learning modeling and surfacing, but if anyone here has a scene already set up that has a decent amount of movement in it we could do some render tests at different framerates to see if I'm just imagining things or if there really is a quality drop at 60fps.
    I've got a 12-core system so I can volunteer some render time for the higher framerate versions. When in doubt, experiment!
  6. #51
    Aug 2006
    Netherlands
    1,685
    Would be interesting for sure...Now, if only I had kept that bulky but fast CRT monitor! I wonder if my current screens go far beyond 60hz.. (for comparison)
  7. #52
    Dec 2009
    Seattle, WA
    1,143
    Quote Originally Posted by Hieron View Post
    Oh heck, good point.
    All the info I've dug up indicates that the update speed of my 27" monitor is around 60Hz (27" iMac, now currently being used as a monitor for my 12-core system... Most Expensive "Monitor" Ever ).
  8. #53
    Registered User Ponyboy's Avatar
    Dec 2010
    Wellington, New Zealand
    66
    you work on it?
    Got 2 good mates who work in CG. They laugh whenever you bring up Lightwave.
  9. #54
    Dec 2008
    6,375
    I can sell you some nice 21 inches here :P
  10. #55
    Dec 2008
    6,375
    Quote Originally Posted by Ponyboy View Post
    tell them to speak with Matt or Rob @ Nt for 10 minutes and then see what they say !
    ignorance is bliss!
  11. #56
    tell them to animate a UV map
  12. #57
    Registered User Brötje's Avatar
    Belgium
    120
    That seems to be a worldwide reaction...
  13. #58
    Cultural Engineer Liber777's Avatar
    The Most Chosen City on Earth
    621
    Current infrastructure
    24fps movies in theaters are projected at 48fps, with each frame being shown twice in order to promote persistence and reduce flicker. It's possible that 48fps was chosen because there may be more existing projectors out there that can handle this rate over 60fps.
    << Nothing is true, everything is permitted >>
    DaVinci Resolve, Fusion, Generation, LightWave, ChronoSculpt, NevronMotion, REDcine-X Pro,
    Nuendo, messiahStudio Pro 5, VT[4] v4.6, SpeedEDIT 2...
  14. #59
    Oct 2003
    Orlando, FL
    4,156
    Quote Originally Posted by Liber777 View Post
    Don't confuse the shutter rate with the transfer rate. Film in theaters moves at 24 frames per second.
  15. #60
    621
    Ah sorry, good point. I wasn't thinking that through.
    I wonder if the mechanics of some projectors will allow for 48fps, as well as existing dcp setups.
