Results 1 to 10 of 10
Thread: Cannot Switch Send or Sync
    Aug 2005
    Macau
    14
    Just installed LW10 and I find that I cannot send items from modeler to layout. For that matter, although I can switch from Modeler to Layout using either the pulldown menu or the F12 key, I can't switch back, and am unable to find a menu or button which enables this switch (it should be at the upper right, no?). Both programs show that they are open in the Hub under 2) Launch Processes, but only Modeler shows up under 1) Processes (see image). For whatever reason, Hub is not seeing Layout. I had the same problem with LW9.6, but was in Maya-land for most of that time.
    Clearly some setting is incorrect, or I'm just incredibly dense-- it's working-- just not correctly. Anyone else experienced this?
Name:	Screen shot 2011-03-02 at 7.19.41 PM.jpg
    It's a demo?
    Aug 2005
    Macau
    14
    It's not a demo.
    Never order a Martini in an all-night breakfast bar. RMT
    Try delet the config files.
    Aug 2005
    Macau
    14
    Thanks! How to find them? (Don't want to delete wrong files!)
    user>library>application support>newtek>lightwave>10.0
    Delete only the prefs.
    It's a good idea to repair permissions also.
    Aug 2005
    Macau
    14
    Have repaired permissions and disk. When I look at the config files I see only a couple of pref files, which seem unrelated, but one cfg file called switchtomodeler.cfg (see attachment). Is it likely that this file is the problem? Why is there no switchtolayout.cfg? Which files can I delete safely?
Name:	Screen shot 2011-03-09 at 11.02.49 AM.jpg
    All the files, not the folders.
