Results 1 to 12 of 12
Thread: Node Kindergarten«: Image node outputs
    Axes grinder- Dongle #99
    Seattle
    14,740
    Question Node Kindergarten«: Image node outputs
    (Node Kindergarten«-- you're going to be seeing a lot of these from me.....)
    please feel free to correct any miscomprehensions I display along the way.
    OK, messing about w/Image nodes, at a pre-school level. It weirds me out that an IMAGE NODE has a bump output, but since it has a bump input I'm justifying it conceptually as just a pass-thru. Why? Because an Image comes with no built-in "bump" information, it's just a picture plus transparency, so in my 'mind' a bump output doesn't make sense, except as a passthru from upstream.
    Back in The Olden Days, a bump map was pretty much a grey scale affair that created the illusion of displacement along a specific axis, so I experimentally connect the Luma output to the Bump input of the Destination node (that's the term, right?), but the Node Editor rejects this connection. (!)
    How rude! Where's the vaunted "agnostic" connection? Shouldn't the greyscale of Luma be mapped to SOME bump channel-y thing? Like, idunno, just the x-channel??
    So, connecting the Bump output of the image node to the color input of the destination node gives you the right side of the JPG. So, without any bump input at the Image Node, where is the bump output info coming from? (There's nothing connected to the Bump input in the destination node in this image.)
    One other thing: Blue connections are Vectors, 3 value data, right? So, how come Color isn't a blue connection? Isn't it 3 values?
    Praise to Buddha! #resist
    Jun 2005
    Reading UK
    3,137
    I don't think Vector 3 refers to how many channels it has, but perhaps the type of vector information its passing? (just guessing). Colour information is probably a different type of vector, same as delta's are a different type of vectors.
    Not sure why their is a bump out on an RGB image though...its probably just being converted internally to a 'cheap' bump map.
    i7 X3930/32GB/Quadro 4000
    the escapist zarti's Avatar
    above the ecuator, then, on the right, but not too much
    2,651
    if my memories arent corroded yet , colors dance between 0 .. 255 or 0% .. 100 % ..
    .. while a Vector has 3 scalar components ( usually from 0.0000 .. 1.0 )
    Stuttgart, Germany
    13,677
    Quote Originally Posted by zarti View Post
    Nope, internally they're both the same. I suspect the only reason for the colour coding is to not confuse beginners.
    And at least make it obvious that you're hooking something up that wasn't meant to be hooked up (otherwise you wouldn't need any colour coding).
    The bump output is just what LW internally computes from an image map, which is a displacement vector. It basically looks at the brightness gradients of the image around the current pixel and derives three directions from that (along x,y and z) which are then used to perturb the normal.
    You need both the input and the output because you can daisy chain image textures. The new bump gradient is multiplied by the bump strength, added to the input gradient (which is 0,0,0 if nothing is hooked up to it) and then sent to the output.
    Cheers,
    Mike
    2,651
    Quote Originally Posted by Lightwolf View Post
    Nope'n'Yope ,
    if you apply a component's color ( ex. : green ) to the y channel of an object's position , for a full green ( 255 ) the object goes 1 m up . so you are right . that's a Nope !
    .. but , when you 'see' a value of 255 which you plug somewhere else and it gives the result of 1 ( ! ) ... imagine if you feed an angle channel with that ( !! ); so it is a mess for beginners and distracting for pros . that's a Yope !
    so , ' color coding ' purpose gives the opposite effect to users here . confusion ...
    Seattle
    14,740
    Well, I'm certainly confused.
    OK, I understand that, but why doesn't the bump channel, when connected to the color input, just look like the color output?
    At least I got that right.
    Stuttgart, Germany
    13,677
    Because it stores a gradient/vector, not a colour.
    Cheers,
    Mike
    Stuttgart, Germany
    13,677
    Think HDR. A value of 255 is so... 8-bit
    Cheers,
    Mike
    Seattle
    14,740
    Cheers,
    Mike
    A gradient/vector, derived from the RGB values? ---Seems like an extra step.
    Wait, 'gradient'???
    Stuttgart, Germany
    13,677
    Wait, 'gradient'???
    Bump Mapping 101: http://freespace.virgin.net/hugo.eli...s/x_polybm.htm
    Cheers,
    Mike
    2,651
    i know but i meant , a user sees and tweaks a value between 0 .. 255 while ' under ' ( context dependent ) you are tweaking 0.0000 .. 1.0000 or god knows what ranges in angle's context ...
    we can choose to use even a gif web-palette but again , the lw calcs and generates much more than that . and in general , when a user starts interchanging between those , the perplexity appears printed always in the face of the artist not in cpu . because ' down-under ' the cpu doesn't care ...
    should nt keep pushing artist's friendliness or new users' easyness even further ...
    > to something like this ??
    Stuttgart, Germany
    13,677
    Well, angels are completely different anyhow (and, I agree, should be exposed differently).
    Currently they're radians internally and not even exposed as degrees in many cases.
    Even the colour context depends on your settings in LW though (as far as the picker is concerned).
    Cheers,
    Mike
