Thread: Rendering multiple pages of an assembly
    Movin' from Illustrator macahuna's Avatar
    Jun 2006
    Smoky Mountains, Tennessee
    61
    Okay, I'll admit it. I'm stupid. I must be. I've got a model that consists of six or seven parts. I need to render each of them out as a single hi-res page. Instead of opening the object in Layout and turning everything off except the one object I need rendered - and doing that half a dozen times - I thought that I'd be able to do it this way:
    Open the object
    Turn on Auto Key
    Open Scene Editor
    Turn off visibility of objects I don't need
    Click the Create Key button
    Move to next frame
    Repeat most of the above until all the objects are singled out
    Render scene
    What happens is whatever the last setup I have shows up from the first frame to the last.
    I'm losing my mind! How do I pull this off?
    Thanks,
    Ron
    Nov 2006
    Burbank, California USA
    4,576
    Turning off the visibility in Scene Editor is a global change. Try putting an envelope on the object visibility in the Object Properties window instead. Or you could just move your objects you don't want to render out of frame.
    Profile piece
    2010 Reel
    'The X's' Reel
    Jun 2006
    61
    Nailed it again!
    Dang! I knew that! Unfortunately, since nothing was moving, I shelved all thoughts about envelopes.
    Thanks again, Nick!
    Great reel, by the way.
    Ron
    Nov 2006
    4,576
    Quote Originally Posted by macahuna View Post
    Ron
    Thanks!
    Profile piece
    2010 Reel
    'The X's' Reel
