Results 1 to 15 of 24
Thread: multi_weld and multi_weld2 LScripts
    WIP'd up GruvSyco's Avatar
    Northern California
    249
    Here are a couple of LScripts I made. Still pretty new to this scripting thing (I think this is day 5) but maybe you guys can use these.
    multi_weld was suggested by Remi and and multi_weld2 is a modification for that script based on suggestions by TripleG that uses David Ikeda's Select Loop.
    Hope you enjoy, docs are include in pdf format.
    Attached Files Attached Files
    yeah! u amde that at day 5! very nice!
    i can't wait what u are going to do in the futur.
    good luck-
    Northern California
    249
    Thanks dude, I'm glad you like it.
    Northern California
    249
    Here is the forumized version of the docs:
    multi_weld.ls
    Select points sequentially around the surface in this manner. Run multi_weld.ls to weld up the points.
    multi_weld2.ls
    Select 2 points on first surface and use DI's Edge Loop.
    Shift select 2 corresponding points and use DI's Edge Loop.
    Run multi_weld2.ls to weld up the points.
    Lastly, these are available as standard LScripts so, the noobs can be in awe of my mad programming skillz and the pros can get a good laugh at them .
    Northern California
    249
    And for those hesitant to download the zip file:
    multi_weld.ls
    // Multi_Weld - for sewing up a selection of points.
    // LScript for Remi by GruvScyo.
    // 09/29/03
    // Select points sequentially.
    // Script welds point 1 to point 2 and,
    // repeats thru the selection (3 to 4, so forth).
    @version 2.2
    @warnings
    @script modeler
    main
    selmode(DIRECT);
    pntCnt = pointcount();
    if (pntCnt <2) {error("Please select at least 2 points");}
    editbegin();
    x = 1;
    y = 2;
    while (x < pntCnt)
    {wldPnt = pointinfo(points[y]);
    pointmove(points[x],wldPnt);
    x=x+2;
    y=y+2;}
    editend();
    mergepoints();
    multi_weld2.ls
    // LScript for Remi and TripleG by GruvScyo.
    // 09/29/03
    // Select points sequentially on each edge.
    // using Ikeda's edge loop between each edge
    // select matching points on each surface.
    @version 2.2
    @warnings
    @script modeler
    main
    selmode(DIRECT);
    editbegin();
    x = 1;
    y = (pntCnt/2)+1;
    while (y <= pntCnt)
    x=x+1;
    y=y+1;}
    editend();
    mergepoints();
    Insert Cleverness Remi's Avatar
    Cold Country, MN
    140
    Everybody keep an eye on this guy...he's my new personal script writer....hehe....great job gruv you know you rock...I don't have to tell you........talk to you now
    __________________________
    Ryan "Remi" Hagen
    Animator
    Keyframe
    it's always amazing to see how simple these scripts look...
    How long did it take you to learn to do this?
    Great script btw.
    Jay
    Northern California
    249
    Great script btw.
    Jay
    Not too long... I started on this scripting thing late Friday night. I had a mostly functioning first script the following day.
    I showed that to Remi on Monday and he said.... "you know what would be cool" and gave me the idea for the first script above... I knocked that out in a couple of hours.
    I then showed it to TripleG and he said "you know what would be even cooler" and I knocked the next script out in about an hour.
    I haven't done much programming in the last 15 or so years (other than a little ColdFusion). It's pretty easy to pick up but would be much easier with some better docs.
    Oh, and thanks
    hey very cool, send the links on to Flay.com when your done.
    UltramegaOK Triple G's Avatar
    May 2003
    Los Angeles, CA
    426
    Great work, man...these are awesome scripts, especially for someone new to LScript! But, I've already told you that, so I'll stop complimenting you before your head gets too big with delusions of grandeur...
    Oh, and Remi....I think you and me are gonna hafta wrassle...he's my personal script writer...
    Gregg Domain
    Visual Effects Artist
    www.greggdomain.com
    Get Into Adobe After Effects
    Northern California
    249
    Hey thanks riki. I don't think they are very Flay worthy though. Just me screwin around. Also I can't really host them myself. Just the hits I'm getting from this little thread alone are bogging me down.
    Northern California
    249
    Hehe... thanks man. I appreciate the input you gave.
    Well... judging by avatars...
    Northern California
    249
    I just found out CMan has some very similar scripts... you should check his too.
    ye, multimerge is nonmodal one!
    but the possiblity to use your Lscript after Di2_SelectLoop can be time saver. Now, u can learn how to do nonmodal!
    here an example:
    it's a smooth script.
    c2; c3; t2 =0; t3 = 100; firstime = 0;
    main
    selmode(USER);
    reqbegin("[email protected]");
    c2 = ctlminislider("Strength",t2,0,100);
    c3 = ctlminislider("Iterations",t3,0,100);
    ctlrefresh(c2,"GotoSmooth");
    ctlrefresh(c3,"GotoSmooth");
    if(reqpost()) {
    else {
    undo();
    return;
    reqend();
    GotoSmooth: Null
    t2 = getvalue(c2);
    t3 = getvalue(c3);
    t3 = (t3)+0.01;
    t2 = (t2/10)+0.01;
    if (firstime == 1){
    undo();
    else
    firstime = 0;
    smooth(t3,t2);
    firstime = 1;
    Northern California
    249
    Wow... thanks for that little script... I'll try to work through it. I'm going to dare to show my newbishness and ask "Modal, Non-Modal?"
