Results 1 to 9 of 9
Thread: white circle artifact
    Profesor Pixel Poo Mr Rid's Avatar
    Oct 2005
    Los Angeles
    2,825
    white circle artifact?
    What causes these little circles to randomly appear at the edge of F10 frames? Seems associated with radiosity. Am trying various settings, but have not narrowed it down.
    Attached Files Attached Files
    "O K, so what's the speed of dark?"
    Demo reel 2017
    https://www.youtube.com/watch?v=yOOixvRhcs4
    Oct 2005
    Los Angeles
    2,825
    After lowering the max pixel spacing, I got a black spot over a white spot. Turning down the rays per eval seems to lessen the frequency. Still dont know what is causing this. The previz scenes I am having this GI problem with are very straightforward, no plugs, nodes, or filters. Default GI, 3 bounce, FG interp. Geometry is only color mapped with pngs. The spots only randomly appear in the left (usually upper) edge of frame. I assume its connected with some random GI evaluation, in combination with ... Bueller?
    Demo reel 2017
    Can you post a simple example? It's pretty weird dave
    (and you are not one to ask for assistance without testing thoroughly ..)
    Model: MacBook Pro 10.6.4 - 2.66 GHz - 4GB - NVD GF GT 330M
    Render: Win7 64 - Core 2 Quad Q9550 2.83GHz - 8GB
    Oct 2005
    Los Angeles
    2,825
    Oh, I am the king of 'never heard of that before,' as friends, mechanics, doctors, and tech support will attest.
    I have not tested this one thoroughly to narrow it down, as I have many shots to setup. I am just avoiding radiosity for the moment. It may or may not have to do with the models or textures which I cant post. I hoped someone else had encountered these... anti-nans (?).
    Demo reel 2017
    Oct 2005
    Los Angeles
    2,825
    So, it seems to be the use of an 8-bit image in my skydome that Final Gather has this odd little problem with. It occurred to me that this was the only thing different going on in my scene, and the circles only appeared when the sky dome was somewhere in frame. The artifact disappeared after replacing with a 24 bit version.
    I usually use 8-bit maps, except in skys where subtle gradients get noisy. This was just previz so it wasnt crucial. But who knows what it is about the encompassing dome GI that was bleeding some odd math at the fringe of frame.
    Demo reel 2017
    Oct 2005
    Los Angeles
    2,825
    Today I got one circle on one frame, with no GI or 8-bit sky map, so I still dont know what is causing this.
    Demo reel 2017
    Malmö, SWEDEN
    7,778
    This might be a longshot, but have you tried applying Limit Dynamic range 0-1?
    Senior Technical Supervisor
    Cinematics Department
    Massive - A Ubisoft Studio
    AMD Ryzen Threadripper 3990X (64 cores/ 128 threads)
    64GB Ram
    Quadro 620
    Windows 10 Pro x64
    Not sure but check your ray precision is set to 6, as I got some blotches with interpolated reflection similar to that, when I experimented with lowering it? Otherwise I am struggling to think what it could be?!
    Oct 2005
    Los Angeles
    2,825
    Yeah, I learned not to lower ray precision. When I get time, I'll have to try some tests on the most problematic scene.
    This is up there with the weirdest glitches I've seen in LW, like a UV map problem I had with a penguin mesh. At about every tenth scene load, LW 9.3 would randomly misapply the UV and render little white holes in the color map. The same model had rendered fine in LW8.5 on a prior project. No subD, nothing wrong with the mesh or UV I could find, and too random to pin down.
    Demo reel 2017
