Results 1 to 13 of 13
Thread: This one is kill me!!!
    Jun 2009
    UK
    30
    Hi, I am trying to do something similar in Lightwave from a tutorial found here... http://www.youtube.com/watch?v=ho1sn...eature=related
    Here is a screen grap...
    1: Spline guide of the shape
    2: Spline is placed over a mesh object
    3: Spline is extracted from mesh... the goal here is to ensure that the extracted shape can be sub-patched.
    I am then attempting to wrap the shape extract onto a ring using lwcad.
    Many Thanks
    Sep 2005
    Earth
    3,121
    So what's the problem?
    The only way I could think to do this in Lightwave is to use a boolean stencil onto the shape. It would require a lot of clean-up to make it able to be subpatched.
    Jun 2009
    UK
    30
    @3DGFXStudios I want to be able to create a clean sub-patch object from a spline like the video shows, with less clean-up.
    Sep 2005
    Earth
    3,121
    I wouldn't do it like the tutorial says. I think in lw it's better to make the curly thing in 2D just by extending points (e) and than use the "spline guide" tool to make the thickness deformation.
    Why not just use a clipmap and call it a day?
    Jun 2009
    UK
    30
    @WilliamVaughan can't use clip-map since I want to be able to send the end result to a milling machine.
    Quote Originally Posted by simsimma31 View Post
    gotcha... then there is really no need in making it Subpatch since it will all by Tris when sent to the machine
    Oct 2003
    Orlando, FL
    4,156
    The base shape (without the design) is the subpatched shape from what I see in the video? You bake that shape.
    Then stencil your design onto it?
    Have to admit I am lost on how to do the bit with wrapping the shape into a ring.
    7,993
    Quote Originally Posted by Dexter2999 View Post
    Copy layer to bg, and freeze it. Then use Push from TrueArt's Modeling Pack, and foreground shape will match curvature of background layer. RMB to adjust Tolerance, all points should be projected in one mouse click, in top viewport (important, because Push is using viewport projection).
    Oct 2003
    Orlando, FL
    4,156
    Thank you, Sir.
    Or use this plug from studio hiro
    POINTFIT
    B
    Phone me for free on
    Skype
    My user ID is tir-3dbob
    Registered User ArtGoblin's Avatar
    Jan 2004
    Iceland/Norway
    809
    maybe I'm being an optimist but couldn't you make the "detailed-form-splines" conform to BGobject on another layer to get them to match the bending curvature of the mesh?
