Thread: Joint move line not visible
    When tip move is selected the yellow line used to determine where the to move the bone tip to will not show through the model as does the bone with bone Xray on. The red line for joint move also doesn't show through the model. The same is true the red line for bone split. Again bone Xray is on and the bone is visible. Any thoughts on how to make the lines show through the model? Thanks for any help.
    Hastings, New Zealand
    7,731
    Its a bug IMO and used to work in previous version of LW9. I dont know why it was changed or why it hasnt been fixed since then.
    What I do to get around it is change to wireframe mode so I can see the lines easier.
    Thanks Larry
    I learned to do character animation and spline modeling by using your DVDs.
    Thanks again.
    7,731
    Cool, glad to hear that
