Results 1 to 9 of 9
Thread: SX Breakout Not Detected
    Oregon
    47
    Hi gang,
    First the info
    Windows 7 Professional
    Intel(R) Core (TM) i7 CPU 860 @2.80Ghz 2.79Ghz
    Ram 4 GB (2.93 usable)
    System 32 bit
    Running VT 5 with latest build
    My problem
    When I first got the machine (built by a dealer) everything worked flawlessly. But then after a few months the audio would just 'go away'. The audio meters just above the transport controls would show audio, but nothing would come out the speakers. When I would open the tab that housed the virual audio mixer / switcher / SX 84 breakout box - everything seemed normal. ie audio meters moving on the 'audio mixer' etc.
    If I exit out of VT5 and re-enter VT5, the SX-84 would have the big white letters (outlined in blue) SX Breakout Not Detected.
    I have to power down the computer and restart (rebooting does not fix it) 90% of the time a restart will fix the problem ie.. I may have to restart more than once to get it going again.
    Some days it won't function on initial morning startup.
    I've tried not having any other programs running, but can't find any consistancy in duplicating the problem... and of course.. it is in it's worst mood when the boss wants to see something I've done.
    I have gone to lunch with everything running fine and come back to "no audio".
    When this happens, all of the functions of the editor seem to be fine..
    start - stop - edit - CG - etc
    Some days I can go all day and not have one episode.. other days like today... well, it's frustrating.
    Any ideas??
    Thanks in advance
    John
    Bloomington, IN
    1,625
    -Jeff
    My TriCaster Blog
    TriCaster Tally Lights
    Oregon
    47
    Jeff,
    OK, so it finally quit again this morning. After running the 'cmd' 'run' commands, I found the message 'no analog daughter card', which, according to the link indicates that I have a bad daughter card or no power to the card... the next thing is to check the power connections to it and then see if it happens again...I'll keep you posted,, thanks for your input.
    John
    All of this poses the question. "Can the daughter card be 'going out' and/or how can powering down and restarting the computer 'fix' the problem??
    Bloomington, IN
    1,625
    Flaky hardware is nothing new, it happens all the time. Life would be simpler if things would fail and then stay failed but that's not always what happens. But on the bright side, it could just be a loose power cable.
    -Jeff
    My TriCaster Blog
    Oregon
    47
    I have reseated all the boards - connectors - everything I can think of.
    Still not fixed.. kind-of frustrating... it quit 3 times this morning right out of the gate.. for no apparent reason..and then has been fine the rest of the day.(and I've been working it hard)
    Does NT still repair these boards - if so - would I be better to let the dealer send it back? Any idea what kind of turn-around time I'm looking at?
    John
    Registered User ted's Avatar
    Fresno, CA
    4,216
    Call tech support for an RMA. If you send it overnight, they will return it the same way.
    I would anticipate a couple days in the shop if it's easy to confirm the problem.
    Best of luck!
    Ted R. Ruiz Sr.
    Ad-Venture Video Productions
    Elite NewTek Dealer
    www.editbay.tv
    TriCasters, Most All Models
    Cameras-Mostly HVX 200's
    19,457
    Quote Originally Posted by ted View Post
    Just to mention a timing factor to weigh, there are less business days in the next 10 days or so than most periods. NewTek facilities are closed today and tomorrow, for example. This could have some impact on turnaround.
    Oregon
    47
    Well, I've noticed another interesting anomaly when I loose audio.
    The RS-8 starts involuntarily doing crossfades between Program and Preview. The Auto button lights up, the cross fade happens... the Auto button lights up, the cross fade happens .... continously until I exit VT... and of course when I run 'newtekrtme' it tells me there is 'no analog daughter card'
    I obviously haven't sent the card in to NewTek yet. Wondering if anyone else has had this particular situation... also wondering if this confirms the daughter card problem or could it be something else.
    Fortunately for me, I use VT every day and really can't be w/o it for a long time.. should I call NT support? Will these symptoms be enough for them to give me a definitive answer.... I could send it in when I head out of town (I guess). Right now the once or twice a day that it happens.... is palatable and it's not getting worse... I just fear that one day I'll come to work and VT won't work...
    Thanks for reading and offering any suggestions.
    John
    19,457
    Quote Originally Posted by videojt View Post
    Can't think why not, apart from the long distance charge, which shouldn't be all that great calling from inside the US. FWIW, if it comes to an RMA, turnaround is usually quite quick, and I think they usually ship return by whatever means you use to send the item - so if you overnight it, so do they (not promising this, but it's my impression).
