Thread: newbie question...
    Oct 2009
    Boise, ID
    161
    newbie question...
    When I drag clips into the time line it starts the clip a few frames in and ends it a few frames from the end... What do I change to have it show the full clip start to finish when first placing it in the time line?
    Dec 2002
    San Antonio, TX
    3,830
    for restoring the in/out points to the first/last frame of the clip, press the 'g' key on the highlighted clip.
    If you wish to make this a global behavior, change the setting in the Preferences panel listed as Automatic In/Out Offsets to No Offset.
    Don't stream it - TriCast it!
    Just Tryin' To Help...
    Quincy, Illinois, USA
    1,066
    In Preferences change Editing > Automatic In/Out Offset to "No Offset".
    SB Enterprises, Quincy, Illinois ~ in the backwoods of the US of A
    19,996
    Quote Originally Posted by Scott Bates View Post
    But before you do, you should probably consider the reason SE defaults to chopping 1 second off each end of a clip ... it's so that transitions don't take frames from the part of the video clip you actually want to see.
    LightWave Fan Boi
    Dec 2009
    London, England, UK
    1,215
    Blog Entries
    18
    An absolute godsend in storyboard mode.
