Results 1 to 15 of 22
Thread: Orange Juice
    Registered User jonbee's Avatar
    Sep 2007
    Austin, TX
    67
    Orange Juice
    First, allow me to say how deeply impressed I am by the majority of users in this forum. Your skill and creativity keeps inspiring me to try and become better within the 3d medium.
    Been working recently to bring my amateurish skills up to something I can be a bit happier with. I decided to play around with some liquid and glass today.
    Any comments/criticisms are most welcome.
    Fórum áss clówn Hopper's Avatar
    Jan 2005
    Austin
    3,393
    Nice work so far. Now see if you can put some reflections on the glass. Maybe 1 or 2 luminous poly's, or read up on implementing an HDRI for your reflection map.
    Cheers. Keep at it.
    Playing guitar is an endless process of running out of fingers.
    Sep 2007
    Austin, TX
    67
    Quote Originally Posted by Hopper View Post
    Or read up on implementing an HDRI for your reflection map.
    Thanks for the feedback and are there any good locations for learning about use of an HDRI in lightwave?
    Craptose Intolerant UltraViolet's Avatar
    Nov 2007
    Louisville KY
    279
    Nice JonBee ... Yep, reflections are missing and glass is bit too thick and too narrow on the botom for my taste
    BTW, how did you embed letters into the glass ?
    Maybe 1 or 2 luminous poly's ...
    Hopper, I keep hearing about this luminous poly crap all over the forum (and I used forum search and could not find anything about it in layman terms), only thing I got about it is that is suppose to help with caustics ...
    I have no idea how to create these lil' buggers, is it in the modeler ?
    Please give us noobs some tips, thanks
    These moments, as beautiful as they are, are evil when they're gone...
    Sep 2007
    Austin, TX
    67
    Quote Originally Posted by UltraViolet View Post
    For the purpose of this render, it's a bump map. I could switch to displacement mapping if I needed a view from the side.
    Animated Fool paulhart's Avatar
    San Diego, CA
    758
    Good start, now get a glass of orange juice and look at it... Your orange juice is too "plasticky" and needs to have some translucency and light transmission, just my opinion... carry on.
    Paul
    An eye for an eye, and the whole world goes blind... Gandhi/MLKing
    Greater consciousness is worth the effort. Be aware.... so sayest the Animated Fool ~ HARTWORKS www.hartworks.net
    Nov 2006
    Burbank, California USA
    4,576
    Quote Originally Posted by jonbee View Post
    You could try hdrlabs.com. Check out the Smart IBL plug-in.
    Profile piece
    2010 Reel
    'The X's' Reel
    Sep 2007
    Austin, TX
    67
    Okay, added HDR and modified the orange juice to have some sub-surface scattering.
    Dimension the Third voriax's Avatar
    Sep 2003
    Perth Australia
    859
    The SSS on the juice made a huge difference.. it looks like very thick/pulpy juice now..
    The glass still needs to be showing more reflections - at the moment it doesnt seem to be reflecting anything. Take a look at a glass in your kitchen, everything reflects off it. Maybe you need an HDR image that reflects more detail?
    Sep 2007
    Austin, TX
    67
    Alrighty, figured out why my reflections were not showing up too well:
    Jan 2005
    Austin
    3,393
    Sure, no problem.
    As an example...
    1. Create a standard single plane 4 point poly (i.e. a rectangle).
    2. Give it a color (preferably a bright tonal color)
    3. Place that "panel" in your scene as a light source (keep in mind that it will be seen in reflections by default).
    4. Modify the surface properties of the panel and turn up the Luminosity channel.
    5. Test render and adjust colors and luminosity to taste.
    In image 1, you can see I've placed two offset polys in front of the subject (marked in red). I added a black border because I wanted the border to show in the reflection (looking at the reference pic, you'll understand why). I also created an entire room so that I could get nice even radiosity bounces to create a more naturally lit scene as if it were a product shot type of setup. It's not totally necessary, but it made it easier to adjust the lighting intensity without using the ambient light (which can wash out some textures if not used sparingly).
    I added luminosity to the far "back wall" poly and the "ceiling" poly directly above the subject (also marked in red). I also gave the ceiling poly a warmer tone (more red). I did this so that I could adjust the overall tonality without having to constantly tweak the surface attributes of the subject.
    In image 2 you can see the very basic surface setting for the left luminous poly (the right is identical).
    You can see the final result in image 3. Notice you can see the luminous polys in the reflection as desired.
    Image 4 was the original photograph that served as my reference.
    I could have easily produced the same end result by using standard lights, but the poly setup was easy, I already had the scene from an older project, and it makes for a much faster render than other lights. With the way I have it set up it's a bit odd in Layout, but then again... it worked and texturing/lighting is not something I'm particularly good at.
    There were only two area lights used in this scene and the render time was less than 1.5 minutes (on a 4.1GHz OC'd Q6600). I could have cranked some of the basic render settings to eliminate some of the aliasing artifacts and overall quality, but it was for the speed modeling challenge and final output wasn't too terribly important.
    Hope this clarifies the mystery for you. I've been there. (still there most of the time).
    EDIT: I have included the robot object (broken up into layers for study) and the entire scene for you to play with.
    Just mess around with the settings and see what you can come up with. Keep in mind that the render settings are low... i.e. RPE, bounces, AS, etc... If you crank them up, the lights will blow out the scene. You'll have to tone down the luminosity, and light intensities.
ID:	88967   Click image for larger version.
ID:	88968   Click image for larger version.
ID:	88969   Click image for larger version.
    Attached Files Attached Files
    Sep 2007
    Austin, TX
    67
    Thanks very much for the lesson Hopper
    Imma look into testing this out.
    Jan 2005
    Austin
    3,393
    You're welcome. But don't read too much into the Layout setup. It was poorly assembled and you would never use these lighting (intensity) and render settings normally. You can get the same results by adjusting the render settings and bringing all the lights down significantly.
    This would be a better lesson in how to NOT setup a scene. Set all the lights and luminosity back down to 0, adjust the render settings to a higher quality first (i.e. bounces, quality, etc.), then bring the luminosity and light intensity up slowly.
    I had quickly blown all the lights out because of the poor render settings, which makes the scene hard to work with inside Layout.
    You'll see what I mean when you open it up.
    Nov 2007
    Louisville KY
    279
    Thanks Hopper, I really appreciate this
    Sep 2010
    CA
    141
    thats very real looking to me.
    I want a glass of orange juice now.
    brb
