Results 1 to 8 of 8
Thread: Vertex map creations
    Hello,
    I was wondering how to create a new morph Vmap.
    Can't find the answer in LScript documentation.
    Maurizio Memoli
    Newbie Member Tom Speed's Avatar
    Liverpool, England
    86
    Here's an example:
    Code:
    @version 2.6
    @warnings
    main
      selmode(GLOBAL); // we'll access ALL points regardless of selection
      editbegin(); // mesh edit mode
      myVmap = VMap(VMMORPH,"Name Here",3); // create a Relative morphmap with 3 elements, x,y,z
      if(!myVmap) error("Could not create the VMap");
      foreach(p,points)
        // assign the x,y,z values for this point to an array, I'll just use 1,2,3 in this example
        values[1] = 1; // x value
        values[2] = 2; // y
        values[3] = 3; // z
        myVmap.setValue(p,values); // set this points x,y,z in this morphmap
      editend(); // end mesh edit session, morphmap now exists
    Should work
    To create an Absolute morphmap, use VMSPOT instead of VMMORPH, everything else remains the same.
    Cya!
    Tom
    Tom, is it the same way to create Weightmap?
    Liverpool, England
    86
    Yeah pretty much:
    myWmap = VMap(VMWEIGHT,"name",1);
    The number 1 is the amount of elements, weightmaps have 1 element, UVs have 2, morphmaps have 3
    Tom
    thank you!
    ups, i got an error with this script:
    @version 2.6
    @warnings
    main
    selmode(GLOBAL);
    editbegin();
    myWmap = VMap(VMWEIGHT,"weight",1);
    foreach(p,points)
    values = 100; //weight value
    editend();
    i got the message error "Coundn't create"!
    What's wrong with this script?
    Sydney
    8,275
    Could it be your calling it myWmap in one part and myVmap in another?
    OOoooO sorry,
    U right thank you!
    great,
    Thanks a lot!
    Another question what about Absolute Morph map creation?
