Results 1 to 15 of 16
Thread: advanced baking from highpoly to lowpoly?
    hello together,
    Im looking for a good way to bake lowpolymodels .
    Some time ago I heard from a plugin that can bake texture and normalmap in modeller, but what Im looking for is a way to bake texture, normalmaps, bump & specmaps and Shadows/GI if possible in one row. After this, the model should use same coordinates (uv textur) for all channels, so its easy to export into 3ds or obj.
    Does anyone has a hint for me?
    Also, If you know a good advanced lowpoly modelling Tutorial for LW please let me know, thanks.
    oh corks
    Aug 2010
    end of the line
    888
    thank you, i totally forgot about microwave. Has anyone ever tested it?
    North Carolina
    11,399
    That's expensive, you might as well just use Dpont's normal cast node. Or invest in a highpoly sculpting/baking program.
    Registered User TeZzy's Avatar
    Mar 2006
    NZ
    256
    not sure if this is what you are looking for.....but try xnormal
    http://www.xnormal.net/1.aspx
    won't do shadows and GI obviously
    oh and it's free
    “Every block of stone has a statue inside it and it is the task of the sculptor to discover it” - Michelangelo
    DragonFist WyrmFriend
    Jan 2005
    Sunland, CA
    1,172
    3D Coat's re-topology tools would probably address your needs. It can auto-create a low-poly mesh and re-top to it, gives some great tools for manually doing it and can import a low-poly and apply the re-top to it.
    There's a free trial, works directly with .lwo objects (can output obj) and it cost quite a bit less than the other two sculpting packages.
    _____________________________________________
    Shawn "DragonFist" Smith
    oh corks
    Aug 2010
    end of the line
    888
    Years ago I used Microwave at one of the places I worked to bake out procedural textures to maps. I only used it for color maps and some baked in lighting, and it worked fine for that.
    I have a funny half-memory about it that it wouldn't let you bake out the base values of the diffuse maps... only the "lit" diffuse values, and that I had to do some annoying screwing around putting the diffuse mapping into the color channel and then baking the diffuse out like that. But I might be wrong! It *was* maybe... well... maybe 9 years ago now...
    Edit: Lordy! I just went and looked at the price. That really *is* expensive. Sheesh. I wonder if they ever sell any at that price?
    Registered User calilifestyle's Avatar
    Jun 2006
    cali, Santa Clarita
    1,561
    Blog Entries
    4
    Yeah one point they also had some kind viruses on there website.
    Ell no 'ta enamora' de mi, yo tampoco
    May 2003
    Brazil
    133
    You can use surface baker + render buffer exporter (to choose channels)
    for normal map you can use a free modeler plugin called "NormalMapCreate"
    Registered User Dreamcube017's Avatar
    Jun 2010
    Ohio
    305
    This isn't in lightwave, but you can try Crazybump. It looks pretty cool and can bake detail from high to low poly jmeshes. I don't know about shadow maps, but I think it does AO.
    http://www.crazybump.com/
    Registered User Ågrén's Avatar
    May 2007
    Finland
    117
    Quote Originally Posted by Dreamcube017 View Post
    CB cannot do that. Generally speaking it's good for displacement/bump map -> normal map conversion. It's problematic with photo -> normal conversion as it sees brighter values more elevated than dark values. Works with some photos - some it totally ruins.
    I've given up on baking in LW long time ago. The feature always seemed rushed. I use mostly Modo and in-house tools these days.
    thank you all for your feedback.
    Im trying out the PB Texture Baker and its very good working so far. Only with bigger and more detailed objects I get some problems.
    @ Dragonfist: Is there a tutorial about how to bake from highpoly to lowpoly in 3dcoat? Can you give me some more details about that?
    May 2003
    Brazil
    133
    Mate, Try to do it:
    1 - Make a low poly version
    2 - Detail the mesh as you wish (zbrush, mudbox, 3d coat etc)
    3 - put the low poly version in a layer in modeler and the high poly mesh in other layer
    4 - Make an UV map for the low poly object.
    5 - Apply NormalMapCreate plugin (found in http://amber.rc.arizona.edu/lw/plugins/NormalMaps.zip) by puttiyng the low poly layer highlighted and the high poly layer on background, applying to the low poly uv you have made in the last step.
    It will create your normal map.
    6 - Send both meshes to layout (the low poly mesh with opened uv and the high poly mesh with the textures)
    7 - Set the high poly texture as 100% luminosity and 0% diffuse
    8 - Set the low poly mesh as "unseen by the camera" and "unseen by the lights"
    9 - Select surface baker camera and set the low poly mesh and low poly mesh uv as the source.
    10 - Render it.
    You must tweak a bit the camera to achieve the better results. It works well to me.
    I hope it helps.
    thank you very much ZE COLMEIA, im testing this now at the moment, and it seems to work very good so far.
    May 2003
    Brazil
    133
