Thread: Edit FX Frustrations
    Jan 2004
    Virginia
    144
    Hi all, I've been over the same scene several times and each time I use the Edit FX tool in Layout, the system crashed. I am on the iMac OS 10.5.8 and using LW 9.6. There's also an error message that pops up when I activate cloth FX: something about a node error. Any idea what the problem is? Your help will be much appreciated.
    Create a new scene and load the pfx on a new emitter. See if you can use edit FX there. If so then you may need to rebuild your scene.
    Jan 2004
    Virginia
    144
    Thank for the info. What I ended up doing was to delete the Layout and Modeler preferences and it worked. However, when I open a different scene to edit the FX, it crashed again. I have to keep deleting the preferences and resetting the computer.
    Save a copy of your preferences before and after the crashing. And send it in as a bug. Since it's so reproducible. They should be able to dif the files and see the problem very easily.
