Results 1 to 2 of 2
Thread: How to get polygon surface from DXF?
    Jul 2010
    Here
    4
    Hello All
    I'm trying to import some shapes from DXF. When I open it in Modeler I get correct shape, but I can't get it as polygons - main shape which is drawn in Solid Edge and exported to DXF seems to be only spline (?).
    I'd like to get this shape as polygons. How to make it?
    When I extrude this shape I get only "walls" but no top or bottom surface.
    I hope, I've made myself clear.
    TIA
    Regards
    Maciej
    17,263
    Just out on a limb here, what did you import dxf with?
    I donīt have solid edge but I would suspect that it might
    be located in your solid edge export settings, be sure to check it exports
    surfaces and or polys, check your dxf export settings there first.
    Michael
