Thread: LW Water Shader renders with black lines
    Jan 2008
    Amsterdam
    8
    Hi Everyone,
    I have a really annoying problem with te water shader in lightwave 9.6, I have made a ocean and used the LW shader, played around to get the look and feel, but when I render it their are thin black lines and sometimes white specs in the render, As I watch it render it makes the image then seems to add them in at the end.
    If I turn of the LW Water shader and switch to fast fresnel then the lines are gone.
    Plus when I package the scene and take it home to work on The shader settings reset themselves and I have to turn them on.
    At work I use a mac intel and at home a PC intel.
    two links
    http://www.newtek.com/forums/attachm...1&d=1280144795
    Any help would be appreciated.
    John
    hm, looks like a bug, maybe it's related to this bug somehow...
    http://www.youtube.com/watch?v=9JKn6...os=GzHg4Gqeo8s
    Jan 2008
    Amsterdam
    8
    No Luck
    Thanks for the link, but still no luck,
    Registered User Kuzey's Avatar
    Melbourne
    5,262
    Do you have multiple layers of the water object? I was thinking one layer might cut into the other....causing the effect, something like this:
    http://www.newtek.com/forums/showthread.php?t=109774
    Kuzey
    Jan 2008
    Amsterdam
    8
    No but thanks
    I am using the tutorial from simply lightwave ocean.
    One object with displacment map, so I turned off all displacments and anything on surface. Still lines, and they are not on geometry. I first thought part of reflection or reflection Angle.
    To be honest I need help and I can wait till november(lightwave 10). for bug fix of this.
    More important is I have a beautiful project I am working on in Amsterdam and could do with help to make better. They have an educational maritime museum I am creating for one of there rooms a panoramic sea voyage.
    Basiclly a room 20 m in lenth 4 wide shaped like a running rack(a boat) we will project on all the walls a sea voyage, panoramicly.
    we are to tell a story off the early voc untill the second world war.
    if your interested in helping please email me,
    Ultimate creativity on a project that will be there for at least 30 years.
    8,079
    I would try switching Render Globals > Threads to 1 to see whether it's multi-threading issue..
