Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: Ambient Occlusion
    Registered User stevenpalomino's Avatar
    Jan 2010
    Kansas City
    607
    Ambient Occlusion
    I'm having the hardest time trying to figure out Ambient occlusion in LW. It seems like it's much easier in other packages, but in LW you have to add it as a node? I think I might be doing something wrong then because it just turns my materials into grainy objects. Is there a tutorial out there that can clarify the process? I've watched William Vaughan's tutorial on it.. but I've already got a material set on my object. Do I need to make a separate pass or something? Thanks in advance!
    Steven
    PS you can see in the attachment I've added the node only to the pants
    Registered User Kuzey's Avatar
    Melbourne
    5,262
    edit...I see you saw the video. I would play around with the setting and see what you get. Object scale might be a factor in how it works too..
    Kuzey
    Jan 2010
    Kansas City
    607
    finally figured it out. I was using the "infinite" option instead of the ranged option in the occlusion 1 node. here's some before and after (with & without amb occ) pictures. Sure it needs some tweaking.. but worked after all next question:
    How in the world do I get soft shadows with area lights??
ID:	86110   Click image for larger version.
    \\ is sparkling // Iain's Avatar
    Jun 2006
    Edinburgh
    4,441
    Quote Originally Posted by stevenpalomino View Post
    Scale the light up. Bigger the light, softer the shadow.
    portfolio
    The Liver is evil and must be punished!
    Melbourne
    5,262
    You can get nice soft shadows with Dome lights...there's a video on that one too
    Kuzey
    Jan 2010
    Kansas City
    607
    oops forgot about that :P thanks
    Architectural Designer Tzan's Avatar
    Nov 2005
    Boston
    598
    Just thought I would post this.
    100% SG_AmbOcc_Exp no lights.
    Jan 2010
    Kansas City
    607
    Howd you do that?? Photoshop?
    Nov 2005
    Boston
    598
    How did I do what?
    Modeled in LW
    Applied SG_AmbOcc_Exp.p shader, You can get that from Flay. there is also a node version.
    The ambient was set to 100%, no lights
    color 201...
    diffuse 90
    Thats rendered straight out of Layout, no photoshop
    Jan 2010
    Kansas City
    607
    hmm.. I installed the plugin.. but where is it under :S
    Jun 2006
    Edinburgh
    4,441
    Add it to your material in the Shaders Tab of the Material Editor.
    Default settings are pretty good-just change the Max Ray Length (basically the extent of the effect) to suit the scale of the object.
    portfolio
    Jan 2010
    Kansas City
    607
    ahhh okay I see.. would it plug into the main diffuse of each material? seems like it's a bit of a hassle to plug it into each material. I guess it'd be easier to just assign it to everything and set it up as a pass correct?
    Speaking of passes. How do I set up an occlusion pass? I'm coming from XSI so it's just "Create occlusion pass" there and then it renders and comps automatically.. How do I do this in LW?
    Rasterbator Bog's Avatar
    Los Angeles, USA
    4,096
    Ha ha ha... "create occlusion pass" indeed. No, we work for a living around here :P
    You have to save a copy of your objects out with the Ambient Occlusion shader node applied (or as stated the SG_AmbOcc shader or node) to all your objects' surfaces. Then set your scene up with 100% ambient light, no other lights, saving out to a different folder.
    Then take a drink
    It's a heckofalot easier with ShaderMeister (which is on my to-buy list, below beer but above new socks) but that's a commercial tool.
    Breakouts in LW are, by default, A Bit of a Pain. If anyone's got a better way of breaking out an AO pass, I'm all ears. Eyes. Monitors. Whatever.
    I should say, though, that's specifically AO. For all your other buffers (Spec, reflec, yada yada) you want to pop open your Image Processing panel, and locate the Add Image Filter dropdown in the Processing Tab.
    Adding the Render Buffer Export plugin will let you set buffer savers for each channel. Yes, you need a separate instance of the plugin for each channel. Yes, you can have another drink now.
    EXRTrader from those same fine and fantastic folks at DB&W, who also do ShaderMeister, will let you handle all your buffer savers flexibly in a single plugin, just like grown-ups do.
    Mark Hennessy-Barrett
    www.imaginetix.co.uk
    www.shaxam.com
    ...and then I was on fire.
    Jan 2010
    Kansas City
    607
    Yeah.. i was trying to find a less painful way of doing ambient occlusion.. but I guess i'll have to buy the plugin.. although.. the amb occ + Exrtrader deal doesn't look too bad.. $100 for something that'll save me hours at rendertime? Yes please!
    Los Angeles, USA
    4,096
    The folks who built those tools are Top Notch as well, which is always good. I like doing business with good people.
    www.shaxam.com
