Results 1 to 8 of 8
Thread: Round Motion Paths
    unleash the nerd within Holdesta's Avatar
    May 2010
    Minneapolis
    37
    Round Motion Paths
    Is there a way to set indiviual origins...as in I have a moon orbiting an earth, but I have 20 sets of them. So is there a way to set moon 1's origin to Earth 1's center?
    Is there a position editor other than numeric move?
    If you have three spheres, and you want one to cirle the other two in a eliplical path...what's the best way to set the curved keyfarmes?
    Please and Thankyou
    Unleash the Nerd Within
    Malmö, SWEDEN
    7,778
    Study the scene I have provided. It might give you an idea of one of many ways to set it up.
    Just load it and hit play to see what is going on.
    Cheers!
    EDIT: Noticed that I had applied the pointconstrain at frame 100 instead of frame 0. *doh* Changed the attachment.
    Attached Files Attached Files
    Senior Technical Supervisor
    Cinematics Department
    Massive - A Ubisoft Studio
    AMD Ryzen Threadripper 3990X (64 cores/ 128 threads)
    64GB Ram
    Quadro 620
    Windows 10 Pro x64
    Oct 2003
    Orlando, FL
    4,165
    Not sure exactly what you want.
    You could parent the moon to the earth.
    Or...
    maybe use two nulls, keyframe one in a to and fro motion, key the second to a rotation,
    combined that could make your ellipse
    or something like that.
    Good Luck
    May 2010
    Minneapolis
    37
    Thanks so much for the advice....I think if I just apply a spline curve as the motion path I'll get what I want.
    Is there and easy way to convert points of a selected geometry into a spline?
    EX I have a perfect elipse bisecting both of my spheres and now I want to just use the outer points to create a spline path.
    Nov 2006
    Burbank, California USA
    4,576
    You can select the points and use the Make Curve button. Though if you're motion path is just an ellipse it's probably be easier to do it in Layout. This way you can use the Graph Editor to change the timing.
    But the spline path option is definitely possible.
    On a side note if you ever draw a motion path you like but need to control the animation along it in a very specific manner the pathAnimationIA script is very useful.
    http://flay.com/GetDetail.cfm?ID=1743
    Profile piece
    2010 Reel
    'The X's' Reel
    May 2010
    Minneapolis
    37
    You always give me clear answers
    How would I go about making a perfect elipse motion path in Layout?
    Nov 2006
    4,576
    Something like this might help. The ellipse isn't perfect but you can adjust the motion of the ellipse null to get it to do what you want.
    Profile piece
    2010 Reel
    'The X's' Reel
    Oct 2003
    Orlando, FL
    4,165
    What I was trying to suggest.
    Not the most scientific but simple.
