Results 1 to 15 of 23
Thread: Multishift only working on 2 polys
    I have this mesh shape of 525 polys and I need to multishift it but it's only working on 2 polygons. If I deselect or get rid of those 2 nothing at all happens. I have tried everything I can think of including merging points, unifying polys, and running LWCad 2.5's Fix Polys tool. Any idea what could cause this?
    Here's a video:
    http://screencast.com/t/MWRiNjli
    ~~Phil Nolan
    Would someone have a look at this? it will not multishift at all.
    Attached Files Attached Files
    ~~Phil Nolan
    Dec 2006
    Philadelphia, PA
    5,738
    That is really weird!! I tried about 5 different things to get the MS to work on the model and nothing worked. Only those two polys.
    ...and don't try to merge all the polys and then multishift.... lol... crash!!
    Dec 2006
    Philadelphia, PA
    5,738
    extrude does work on it if you're looking to make it have some thickness.....
    I got the same result that you describe when I try it using Multishift with the group option turned on. Just out of curiosity I tried it with the bevel tool in modo and it works as expected with the group option.
    huh. Yeah I'm trying to make the strips thinner, or the empty squares bigger if you want to think of it that way.
    See it's the mesh under this headlight, but I realized I made it too thick.
    http://www.carsbulletin.com/wp-conte...8/11/car40.jpg
    ~~Phil Nolan
    Dec 2006
    Philadelphia, PA
    5,738
    multishift_bug2.lwo.zip
    well it's not perfect but you can....
    extrude - alot - try to make it perpendicular to faces
    then select original faces with lasso select
    expand selection one time
    deselect original faces
    use move plus to do a normal move on all of the 'middle' faces
    then select end faces
    expand selection once and delete to only have the original faces.
    that's how I got this model.
    Dec 2006
    Philadelphia, PA
    5,738
    Silo did it too but it was a little messy...
    multishift_bug.obj.zip
    Fixed
    Hmm I'll look at that. One thing I noticed is that the Edge Statitistics says there are 789 edges that are only connected to one polygon. When you select them you get this:
    ~~Phil Nolan
    Dec 2006
    Philadelphia, PA
    5,738
    Quote Originally Posted by Philbert View Post
    yep, noticed that too....
    Fixed
    Thanks, what did you do? Oh did you just delete those two on the lower left?
    ~~Phil Nolan
    Dec 2006
    Philadelphia, PA
    5,738
    Fixed
    yeah... and.... lol
    what did you do to fix it???
    Cow Orker cagey5's Avatar
    Manchester UK
    3,273
    Wouldn't that be because those edges are only connected to one poly..?
    Forum Tips
    If English is your first language, you should know it's 'losing' and not 'loosing'!
    Manchester UK
    3,273
    Looks like Probiner deleted the only two polys that previously worked..
    edit.. Nope scrap that, there's more to it than that.. Hmmmm
    Forum Tips
