Results 1 to 12 of 12
Thread: increase realism
    increase realism
    How can increase the realism of architectural projects?
    I like to know if is possible increase the realism of these images.
Name:	Sabana Alta 1.jpg
ID:	84953   Click image for larger version.
Name:	Sabana Alta 2.jpg
ID:	84954   Click image for larger version.
Name:	Sabana Alta 3.jpg
    Aug 2006
    Eureka, CA
    6,962
    The tiling of the bricks is pretty obvious, I use a brick or block DPont procedural from Denis Pontonnier. You can find them here:
    http://pagesperso-orange.fr/dpont/main_en.htm
    RmanCollect - Textures and Nodes
    shrox www.shrox.com
    Heavy Metal Landing
    San Antonio, Texas, USA
    13,055
    As with many renders (including my own) everything is too clean, I know the client doesn't want to see things with rubbish and muck in the streets etc. but a little variation in textures goes a long way.
    If you can try and paint the maps to add variation instead of the old procedural method (which is a quicker way, but still often CG looking).
    Atmosphere. Try turning on fog (very faint) things get lighter the further away they are, a lot of outdoor renders never use this at all, so they are all unrealistically clear.
    Also, is there _any_ depth of field in the scene? A _very_ small amount might help.
    Are you using 'Real Lens' camera too? If not try it, the subtle characteristics from a real lens will also add to realism.
    UI / UX Designer @ NewTek
    Aug 2006
    Eureka, CA
    6,962
    Layerss of surfaces work well too.
    shrox www.shrox.com
    Heavy Metal Landing
    Crossed the mantle...CORE Twisted_Pixel's Avatar
    Oct 2005
    Northern Ireland
    536
    Matt & Shrox raise valid points.
    In addition I would add the building placement 'feels' wrong, the grass just slopes up to the edge of the building. Practically this would be unwanted, I would imagine there should be a path around the base of each building, with steps on inclines that are too steep to walk. Though if you are building to someone elses design, this becomes a point to omit.
    A little internal lighting on the multi-story car park might add to the realism also, the blacks feel very dark.
    | Lw 11.5 | Win 8 x64 | Intel Q6600 - Intel DP45SG - 4GB CorsairTwinX - Sapphire HD 4850 Toxic (driver 8.741.0.0) |
    all valid points by the other posters... additionally, i'd desaturate a little bit the images (try around 12-16%) in photoshop, and add a very slight vignetting to the borders to create a photo look and for focusing the eye a bit. if it's your taste, you can also add a very slight 'blooming' effect in PS, as described in several available tutorials around. this could compensate a bit for the lack of physical atmosphere.
    a last observation: the sun shadows look too soft to me, try to make them around as half as soft (moving the area light away from the scene) - on such a sunny day, shadows are sharper. give them a slighly blueish coloration for added realism.
    nice work, otherwise!
    cheers
    markus
    3dworks visual computing
    demo reel on vimeo
    instagram
    Super Member COBRASoft's Avatar
    Dec 2005
    Oudenburg, BEL
    3,179
    What trees are that, they look very good.
    Thanks for these advises, they really help me to improvement my work.
    And is true some clients don't like rubbish and muck.
    Dec 2003
    Portugal
    1,819
    also don't underestimate the power of post production in photoshop or AE or similar
    With a few gradient layers, blurs, noise, etc I changed your render a bit (hope you don't mind) in a way that quite probably isn't at all what the client wants, but just to show what you can do after the render is done.
Name:	Sabana Alta 1_PS.jpg
    Feb 2004
    GA,SC,NC
    300
    I would use VUE vegetation and Vue render. Attached is somehitng I did 2 years ago. You need to WOW the client!
    be a billionaire, share your wealth
    I don't like your palm tree at all, they are difficult I know, they take up a lot of polygons or clip maps depending on how you go about it.
    On the third image the garage and windows on that building are pitch black, very odd considering how bright other shadowed areas are. I have never liked noon sun, but that's a personal taste, I rather have a morning or afternoon feel, orange sun light with blue sky painting the radiosity balances out nicely.
    Fórum áss clówn Hopper's Avatar
    Jan 2005
    Austin
    3,393
    Careful with that blur now... You will turn your skyscraper apartment building into a miniature from a Mr. Rogers set.
    Blur in a single focal point (i.e. don't try to reproduce a shift lens).
    If you look at your final product and can easily imagine a giant finger coming out of the sky to play with the cars on the street.... you've gone too far.
    Playing guitar is an endless process of running out of fingers.
