Thread: Audio Mixer Skin Needed
    Once more into the CPU!
    Oct 2006
    Port Orchard, Washington
    445
    I need an Audio Mixer Skin that has inputs 5 to 8 from the SK-84 removed. Everything else needs to be the same. If anyone can do this please let me now. Thanks!
    PS: While I'm asking is there also a way to put a few more dB number on the Master Audio Out Meter? The O is great, but I would like it it had the numbers likfe the DDRs have them...
    TC Mini SDI 5-1-190425
    -BlackMagic Studio Cam
    -SDI cables
    -Spark SDI
    -LiveText w/SB2
    -YouTube Stream
    _
    SKTV 205
    https://www.youtube.com/user/SKHSVideoProduction
    Production Wizard radams's Avatar
    Tucson, AZ
    1,558
    Hi there,
    This is something that you can do yourself...if you want to give it a try.
    There should be some info here on the forums.
    I have done skin work like making VU meters like an SSL plasma VU. etc.
    but it has been awhile.
    I created several skins that were around here somewhere.
    Just take the skin you want and copy it off to another name...then go in and make your adjustments...then load that skin in and save...
    I used photoshop...and aura.
    Good luck.
    Cheers,
    Ray Adams
    FX and Production Supervisor
    Bloomington, IN
    1,636
    I did these for VT4 they might be close to what you need.
    http://www.digarts.com/Rack Size with Auto.zip
    http://www.digarts.com/Rack Size With Auto 2.zip
    http://www.digarts.com/Rack Size with Auto 3.zip
    http://www.digarts.com/Rack Size Analog Only.zip
    They probably want to unzip into a VT4 folder, I haven't looked at them in a long time.
    -Jeff
    My TriCaster Blog
    TriCaster Tally Lights
    Gear Used: TC1, NC1 I/O, TC 460, TC Mini 4k.
