Results 1 to 15 of 17
Thread: Modelling the Bevel on a Nut
    What do I know? JBT27's Avatar
    Jan 2004
    Chester, England
    2,250
    I must have a mental block or over-thinking or both, and I used to have a tut for this, but I am spending way too much time trying to figure how to make the bevel on a nut, like these:
    http://image.made-in-china.com/2f0j0...yJMpkV/Nut.jpg
    I'd appreciate any clues and pointers.
    Thanks.
    Julian.
    LW 2015.3 Win 10 Pro 64bit
    http://www.take27.co.uk
    Jul 2007
    Tokyo
    366
    have you tried "rounder" in point mode? not edge
    Jan 2004
    Chester, England
    2,250
    Quote Originally Posted by moussepipi2000 View Post
    I hadn't - thanks for the idea - but it's not giving the right result and the corner rounding is a bit messy.
    I'm thinking that a quad mesh with a weight map might do it, or model one segment then Radial Array it .....
    Don't know - maybe this is one of those that looks simple but isn't ..... it's caught me out anyway
    Julian.
    Sep 2006
    Future Past Life
    1,899
    Recently I've been using LWCAD for any rounding that I need, because it allows you to set varying rounded radii for different edges.
    Dec 2003
    Portugal
    1,819
    well, you can try this
    001. start with a cylinder with 6 sides
    002. create a sphere (24 sides) and intersect it with the cylinder
    003. this is what you get
    004. flatten the polygons at the top
    005. delete the side polygons
ID:	84123   Click image for larger version.
ID:	84124   Click image for larger version.
ID:	84125   Click image for larger version.
ID:	84126   Click image for larger version.
    Dec 2003
    Portugal
    1,819
    006. using the statistics pannel choose the polys with more than 4 vertices and fix them (for subpatch later)
    007. select this edge loop
    008. and extrude and flatten it
    009. delete the tris pole and choose the inner loop and also extrude and flatten it
    010. select this loop and use bandsaw with cuts at 95 and 5%
ID:	84128   Click image for larger version.
ID:	84129   Click image for larger version.
ID:	84130   Click image for larger version.
ID:	84131   Click image for larger version.
    Dec 2003
    Portugal
    1,819
    011. the loop after bandsaw
    012. do the same to this loop
    012a. the cuts in bandsaw
    013. do a single cut in this loop at the top (with bandsaw at 5% OR 95% it depends)
    014. another single cut in this loop of polys too
ID:	84133   Click image for larger version.
ID:	84134   Click image for larger version.
ID:	84135   Click image for larger version.
ID:	84136   Click image for larger version.
    Dec 2003
    Portugal
    1,819
    015. hit tab to subpatch it
    you can now mirror it in the y axis to get the final object
    now you must tweak the final shape, but basically it's something like this I guess.
    I hope this helps.
    cheers
    Jan 2004
    Chester, England
    2,250
    Yes - that helps alot Zardoz - thank you very much indeed
    Nice and simple and elegant - guessed it would be - just couldn't see it
    And as BigHache says, LWCAD is good for rounding because of the varying radii ability - use it all the time.
    Julian.
    inside the beltway Riff_Masteroff's Avatar
    Arlington, VA, US
    634
    Threaded Library Available
    I used a Blender to LightWave workflow for creating a "library" of threaded objects. And I did post the library for all to use. Actually I posted three versions with a fourth version (with new cotter pins and eyebolts) to be posted if anyone is interested. The contents were created with a combination of LightWave and Blender modeling. Read the thread for specifics. The nuts come with a internal threaded version and without internal threads.
    http://www.newtek.com/forums/showthread.php?t=106779
    Dec 2006
    Philadelphia, PA
    5,738
    This is also a place where subd modeling works well... if you don't want a subd model you could always freeze the mesh and then clean it up a bit too. (see last pic)
    cage
    smoothed
    refined
    Fórum áss clówn Hopper's Avatar
    Jan 2005
    Austin
    3,393
    I actually use this tutorial. It's very thorough, and is geared toward creating a model that will animate with a corresponding bolt.
    http://www.final3.com/html/tutorials/nut.htm
    It's not in LW, but the tutorial is pretty app-agnostic.
    Playing guitar is an endless process of running out of fingers.
    Super Member nemac4's Avatar
    Chicago
    562
    If you do a lot of these, then QuickBolt might be a good option:
    http://www.iemedia.co.uk/product/plugins.htm
    Arlington, VA, US
    634
    New Revision of Threaded Library Posted
    Its always a great "power" to model anything at all from basic techniques. The postings on this thread should be of great help to all needing threaded stuff/nuts/bolts etc.
    But . . . sometimes . . . in the heat of a deadline . . . its nice to access other work arounds . . . . such as the revised threaded library I posted a few minutes ago:
    http://www.newtek.com/forums/showpos...4&postcount=17
    Jan 2004
    Chester, England
    2,250
    Quote Originally Posted by Riff_Masteroff View Post
    I hadn't seen these up until now - that's very generous - thank you.
    Considering I only posted to get a quick-fix for a nut for a medium shot, there's a ton of good and useful stuff here, as ever on these forums.
    Thanks to all!
    Julian.
