Thread: uv texture subpatch wierdness
    Hello
    I have a subpatched object that has a uv mapped texture. The texture gets messed up in the corner of the object. The object is a really thin box. I used the subpatch for two reasons. Rounding the edges of the box, and to get it to deform nicely with endomorphs.
    How do I get the texture to behave correctly?
    I try to attach a picture of the thing.
    Unfortunately, Lightwave UV's do not fully support subpatches, thus the wavery look to your texture. You can either freeze the mesh or subdivide the mesh you have a little bit to add a little more geometry. This cuts down on the distortion..
    I freezed the object. The texture problems didn't go away. Do I have to uv-map the object again to get it to work? Or any other suggestions?
    Rendering time inceased from 100sec to 150sec per frame. I though't it would drop, as I read in the other thread.
