Thread: Auto Cad to Lightwave
    I have a machining client who uses auto-cad to model their machines, I talked them into getting Lightwave for animating them, what is the best plugin/program to convert autocad to lightwave?
    Thanx in advance, Shawn.
    NDI Camera
    TriCaster Mini Advanced Edition
    Lightwave 11
    SpeedEdit 2.5
    Music by www.soundtraxxmusic.com
    ack ack Markc's Avatar
    Feb 2006
    England
    1,370
    Lightwave can open dxf and 3ds formats from Autocad.
    But I think it depends on the amount of detail in the Cad model, i.e. if it's only 2D plans/elevations or is it a 3D model?
    The problem with Autocad, is it's a pig to create surfaces etc unless your client has used Revit or a similar program.
    I believe they are 3d autocad models with surface colors included, will that much translate?
    NDI Camera
    Lightwave 11
    SpeedEdit 2.5
    stee+cat
    real name: steve gilbert
    http://www.cresshead.com/
    Q - How many polys?
    A - All of them!
    inside the beltway Riff_Masteroff's Avatar
    Arlington, VA, US
    634
    Accutrans (essentially free) has provided me with the cleanest, most accurate translation of 3d/2d ACAD dxf V2000 files. Autodesk provides converters to bring down the version number of files already exported. Polytrans, I use for dwg 3d/2d. That works fine also, but has some initial expense.
    Many times I bring lwo 2d/3d into ACAD via Accutrans. That is wonderful in that I do not need to inform the recipient that I am using LightWave. (don't gloat about this, cresshead)
    Quote Originally Posted by Riff_Masteroff View Post
    hey...my new job starting in April will have to deal with Cad files from solidworks into 3dsmax and lightwave so i'm also looking into such needs right now!
    stee+cat
    Q - How many polys?
    A - All of them!
    I use Accutrans 3D for my file conversion needs. It works well and can read and write many different formats as well as handling scaling between programs. You can find it here http://www.micromouse.ca/ and download the trial version.
