Thread: Speed Edit 2 using VT5 output
    Is is possible to run Speed Edit 2 on the same machine as VT5 and assign an input on the VT5 switcher as Speed Edit 2?
    I would like to use my NTSC monitor when using Speed Edit 2!
    Ron
    19,397
    Yes.
    VT5 USER Rich Deustachio's Avatar
    Mount Laurel, NJ
    1,371
    From what I was told you don't even have to have VT5 running and SE2 sees the breakout box.
    Dynamic Video Productions
    Mount Laurel NJ
    Great!
    I've got everything running, however Speed Edit 2 does not show in as an assignable input into the switcher. I'm missing something and I'm not sure what it is!
    Ron
    19,397
    It's not appearing in your list when you right click on a Switcher patch? Did you select the newtek output option in SE2?
    Steve,
    Is it hard being as smart as you are...it would certainly give me a headache!
    That was it!!! It looks great. Thanks so much for you help as always!
    Ron
    19,397
    Quote Originally Posted by Ron Kirby View Post
    Well, I do get migraines from time to time, and from what I hear I occasionally also cause some (for others) ... but no-one has ever said it was my 'smartness' that was the cause.
    Glad it worked, just the first idea that popped into my head.
