Results 1 to 11 of 11
Thread: How to choose the best camera type!?
    May the sauce be with you starbase1's Avatar
    London, UK
    5,585
    I'm really not at all sure when to use which camera type, and what the requirements are for each. (I did look in the manual for 9, but it didn't help much, now on 9.6).
    When I start to change this sort of thing I often seem to get unexpected effects, such as needing to make surfaces double sided to avoid lit parts appearing in unlit areas where normal maps are, or jagged borders at the edge of the lit areas, (like smoothing has turned off). Or lens flares go wierd, or they go weird with motion blur.
    Is there a guide anywhere on how to choose appropriate combinations of camera type, camera settings, and render settings?
    I'm always getting the feeling I'm not using these things optimaly - wasting render time, or generating cockups.
    The particular case at the moment is for rendering my Earth model for HD animation, (which gave all the issues aboove at some time or another, in various combinations!). The object is basically 3 tightly concentric spheres, the inner one is opaque with a normal map, the next is the cloud layer, with a transparency and normal map, and the outer one is an airglow / haze layer, with additive transparency.
    But a genreal; doc or tutorial would be even more handy.
    Nick
    Nick
    Faith is the opposite of Intelligence.
    Touched by his noodley appendage!
    My Lightwave Graphics & Downloads!!!
    Check out Jeremy Birn's site. It doesn't discuss the actual cameras of LIghtwave but does discuss lighting and rendering passes which can be very helpful when Rendering.
    http://www.3drender.com/
    London, UK
    5,585
    Quote Originally Posted by juniordebo View Post
    Yes, I bought his book on lighting and radiosity, an awesome piece of work, very helpful!
    Not sure it helps with camera chice though...
    Banned OnlineRender's Avatar
    Dec 2008
    Glasgow , Scotland , UK
    6,359
    Still stuck on Classic camera *sigh* but perspective camera seems to be the new daddy ! , render setting and lighting variables are endless ,just deepends on the scene !
    Dec 2004
    London
    4,502
    Perspective camera if you need a regular, well, perspective. If you need something special, then it depends on what you need.
    The 'real lens' thing is a bit pointless, because you can always distort and add vignetting in post-production anyway.
    Are my spline guides showing?
    Malmö, SWEDEN
    7,644
    Quote Originally Posted by Captain Obvious View Post
    Yes, but that also requires larger renders. If the camera can be matched so you do not have to resort to compositing to do distortion and vignetting it does add to the saved buck, so to speak.
    Senior Technical Supervisor
    Cinematics Department
    Massive - A Ubisoft Studio
    Intel Core i7-4790K @ 4GHz
    16GB Ram
    GeForce GTX 1080 8GB
    Windows 10 Pro x64
    Dec 2004
    London
    4,502
    We run our photos through undistortion software instead.
    Quote Originally Posted by starbase1 View Post
    Nick
    Nick
    Hi Nick.
    Since you have gotten dick squat for answers here I will try and chime in.
    The classic camera in Lightwave is excellent however its excellent at the sacrificing of speed compared to the advanced camera types (perspective, real lens etc) in certain cases.
    One of the biggest issues some people have with the perspective camera - which I run into all the time when dealing with bad models is non-planar polys that used to render okay (no holes in the mesh) - rendering all frakked up with massive holes in them.
    The reason why you are probably seeing this more and more is that most people couldn't "see it" way back when before the ACT were introduced like the perspective camera. So if you have models that were built in LW 8.5 for example, that render fine in 8.5 or in 9.x with classic but frak up in perspective camera - that should be the first thing you look at is non-planar polygons.
    the other thing is intersecting polygons or polys directly on top of each other. While it used to be okay to do this in LW pre9.0 and in some cases was super handy (decals on stuff for example) - in some cases depending on what is going on - Lightwave can't tell if something is over or below another poly and it will start to twitch. Expecially if rendered over a network. One machine will say "its above" the other will say "its below". Insane!
    But it makes some sense, but it can be fixed on newtek's end. Still, the problems you are getting with lensflares I couldn't tell you about unless I saw a scene file or example image.
    Lithium.Kat
    DJ Lithium | KAT! =^..^=
    Black Tiger Recordings
    http://www.blacktigerrecordings.com
    Founder and Citizen of Liberty3d.com
    www.liberty3d.com
    Dec 2004
    London
    4,502
    Quote Originally Posted by djlithium View Post
    More specifically, non-planar n-gons! Any quad polygon will pretty much always render fine in any Lightwave camera, no matter how distorted it is.
    If you model out of four-sided polygons, you basically don't need to worry about how planar they are, unless they're *incredibly* distorted.
    London, UK
    5,585
    Thanks for the suggestions DJ lithium, much appreciated!
    The flare thing seems to be that vector blur hates flares, but I intended it more as an example of a general issue where effects or options don't play nice with each other...
