Thread: Motion question
    Super Member sublimationman's Avatar
    Mar 2007
    Carlsbad, CA
    517
    Motion question
    I mostly create still product images so my animation skills are a bit low. One thing is that when I do animate it's almost always mechanical in nature (doing one now) and I wanted to know if there is a way to make "linear" the motion default. Currently when I make key frames it uses TCB Spline as default making my job a lot more difficult
    So basically is there a way to set the default to linear?
    Thanks!
    Sydney
    8,275
    http://www.dstorm.co.jp/english/plug....htm#GraphType
    This allows you to set a default key type when using Create Key, or change keys to a default type in the graph editor
    King of Trentonia trentonia's Avatar
    Rocket City
    352
    Open the graph editor, select the "More" dropdown, select "Graph Editor Options...", under the General tab change Default Incoming Curve to Linear or whatever, then select OK.
    With velocity expressed in furlongs per fortnight, it is essential that the basic application be applicable to the end item requirement.
    Mar 2007
    Carlsbad, CA
    517
    Very good. Thanks!
    Quote Originally Posted by Dodgy View Post
    Very usefull. Thank you!
