Thread: My last project
    Mar 2009
    france
    26
    My last project
    hello i just want to share with you my last project i still working on !
    and i have a little question i asked myself without any solution !
    I start to model this head every think was ok but in my viewport, i can see i have 72 polygon with more than 4 points.
    On my model every think look great why is this a bug ?
    What do you thinking about ?
    http://picasaweb.google.com/lh/photo...eat=directlink
    I made the UV in blender but i m' not very happy with the result i should restart the UV soon !
    After the UV i will make the detail, the brain and texture painting in z brush ! i still have some work to accomplish it !
    thank you
    Looks very nice and fun.
    Why do the UV in blender? PLG UV does the job.
    Has for the 'bug', it's not. You meant you did your model with all quads, right?
    So what you are seeing is Point Statistics, not Polygon Statistics. In Point Statistics you can see the number of points that belong to 1 Polygon, 2 Polygons, 3 Polygons, 4 Polyongs and More than 4 Polygons. Wich is not the same of Polygons Statistics wich show you the number of polyongs that have 1-Point, 2-Points, 3-Points, 4-Points, More than 4-Points.
    So change the Statistics Panel to Polyongs (space key) and you will see if your model is all quads or not, this way.
    Cheers
    Cheers
    Mar 2009
    france
    26
    ahhh yes it's right i'm sorry i'm biiiiiiiiiiip !
    thank for the comment !
    I did the uv in blender because i think blender have great uv tool set and i know him as well.
    I work on a mac and i tryed to install plg uv and it seems failed to load on my machine !
    A lot of plugin failed on mac osx !
    I don't know if i do some think wrong !
    so thanks you and i will post my base drawing maybe this evening !
    Dec 2006
    Philadelphia, PA
    5,738
    The plg uv plugins do not work on the UB version of lw. Blender is a good alternative for mac users these days for uv.
    Mar 2009
    france
    26
    an update
    hé just a little update to post the next step for my model
    the brain and the sketch !
    The sketch give you a little idee of what i expect to realize !
    I hope you like it thanks
    Mar 2009
    france
    26
    an over update !
    i continue to post my head work this is the head with zbrush details still some work on it !
    all your observation will be great !
    Mar 2009
    france
    26
    need some help please
    hello
    I continue my detail work on my lightwave model but the think are
    quite hard !
    i try to explain what i do actually and how i prefer to work !
    i have my head model in lightwave i modeling all the geometry in different layer the face on the one the tooth on the second layer the brain on the third etc etc ...
    after i apply all the surfaces i want on my geometry in the modeler !
    i save it !
    after i just have to open it in blender with the lwo import and my model is open with all surfaces convert in different object very usefull for the
    uv mapping i think !
    so i made my uv map by object, the face, the eyes, the tooth etc etc
    after i save it and export it with the lwo exporter !
    When i open it in the modeler all my uv map are apply on my differents surfaces !
    My question is there is a way to export all the surfaces the same way in .obj format to open it in zbrush with all surfaces apply to subtools geometry !
    i want my face with is uvmap on a subtool
    my tooth with is uvmap on the second subtool
    my eye with is uvmap to the third etc etc ....
    actually i must export it at once and sculpt it !
    thank you i hope you understand what i try to say !
