Page 1 of 4 123 ... LastLast
Results 1 to 15 of 54
Thread: Free LScript Pack: Coord Tools - No more writing down coord values!
    San Antonio, Texas, USA
    13,057
    Arrow Free LScript Pack: Coord Tools - No more writing down coord values!
    Hi all
    I've updated my 'Mirror Stored Pack' to include more useful tools that are "stored coordinate aware" (Download at bottom of this post).
    This pack is now called 'Coord Tools' as it's not just mirroring anymore. It now includes the following scripts, all of which work with the principle of storing the bounding box centre of any selection, be it a single point, edge, poly face or the whole object:
    • Store_XYZ_Coords.ls - Globally store any selections bounding box centre
    • Reset_XYZ_Coords.ls - Reset global coord to 0,0,0
    • Mirror_Stored_X.ls - Fast Mirror across X of global stored coord
    • Mirror_Stored_Y.ls - Fast Mirror across Y of global stored coord
    • Mirror_Stored_Z.ls - Fast Mirror across Z of global stored coord
    • Mirror_Stored_UI.ls - Mirror across global stored coord with options
    • Move_Stored.ls - Fast Move to global stored coord (first point on geometry as datum)
    • Moved_Stored_UI.ls - Move to global stored coord with options
    • Radial_Stored_UI.ls - Radially array using global stored coord for centre
    • Rotate_Stored.ls - Rotate using global stored coord for centre
    Also included is a menu branch (as seen in screenshot) to make it easy for you to import into your config.
    Here's a mini video tutorial showing it in action:
    QT H.264 (38MB Zipped)
    Coord_Tools_Pack_v1.0_Video_Tutorial.zip
    If anyone wants to make their own scripts work with this globally stored coord, use the following code to grab the values:
    Code:
    stored_x = number(globalrecall("stored_x", 0));
    stored_y = number(globalrecall("stored_y", 0));
    stored_z = number(globalrecall("stored_z", 0));
    The '0' can be replaced with any default value you wish if the 'stored_x', 'stored_y', 'stored_z' variables are not present.
    Hope you find them useful!
    Cheers
    Matt
    Attached Files Attached Files
    UI / UX Designer @ NewTek
    Steadily declining... wayne1 huffman's Avatar
    Dec 2003
    Burbank, CA
    75
    Sweet! Thanks Matt- what versions will this work with?
    13,057
    Quote Originally Posted by wayne1 huffman View Post
    Oh now you're asking!
    I guess the only pre-requsite for this to work is the LScript version that brought in the globalstore() and recall() functions. Have no idea when they came in. I have put version 2.3 of LScript in the scripts, but I really should go and check, because that might be higher than needed.
    I guess the easiest thing to do is to try it and see if any errors are thrown up!
    I don't see why it wouldn't work on versions lower than 9.x. They are LScripts, so are platform independant also.
    inside the beltway Riff_Masteroff's Avatar
    Arlington, VA, US
    634
    Thanks Matt. I just installed and interfaced them. They very well might be quite useful to me . . . have some detailed modeling work to do right now.
    Thanks matt, for sharing. You just answered to this post in some extent =)
    Cheers
    13,057
    Seems you and I share the pain of writing down coordinates for stuff!
    It agree with your post though, not only for numeric entry but copy / pasting too (which these scripts) go some way to solve.
    I know it's bad form to plug your own stuff, but I do find these incredibly speedy and useful, and I've found myself using them in allsorts of ways I never intended!
    Registered User npix's Avatar
    Apr 2007
    Craiglang
    63
    Much appreciated Thanks!
    This is fantastic tool, something twat LW should have/get years, years ago, I've often wished i could copy/paste X,Y,Z values of POINT info before starting Radial array or mirror tool for many projects but i had to write them down manually on paper/notepad or copy/paste one by one while activating/deactivating array tool (undo after every try).
    Thanks Matt this will help more in everyday modeling sessions .
    RAM-Studio
    WS - Dual Xeon E5-2698v4/128GB/Win10x64/4xRTX 2080Ti
    the escapist zarti's Avatar
    above the ecuator, then, on the right, but not too much
    2,651
    small, but tremendously useful ... even for those who have lwcad. thank you Matt! =)
    13,057
    Thanks guys!
    There does seem to be some oddness happening with the Rotate_Stored.ls script.
    Currently it does this:
    undogroupbegin(); // Group all changes under one undo
    Do rotation stuff
    undogroupend();
    Sometimes it works, sometimes not. Could be the way I've done it, or undogroup functions are bust, not sure.
    But array and move works fine with using only one UNDO/step.
    RAM-Studio
    13,057
    Arrow Small Update ...
    Make a requested change to the 'Radial_Stored.ls' script.
    Instead of saying '# or Copies' in the UI, it now says 'Total', which makes more sense.
    When you download the attached script, remove the '.txt' from the filename (needed to be able to upload without Zipping it).
    Then replace over the old one.
    13,057
    Quote Originally Posted by Lewis View Post
    They work differently because they fire their functions once, the Rotate_Stored.ls one is firing the Rotate command however many times you change it.
    I need to look into it, I'm sure it's possible.
    Damn, Matt...
    This is soooo sweet!
    Thanks!
