Page 11 of 11 FirstFirst ... 91011
Results 151 to 161 of 161
Thread: can you testrender this scene for me? (on fast machine)
  1. #151
    so you say perhaps we gotta give that up for a test
    i got q6600 at 2,91 to butt in with
    though ofcause theres a few christmas days here where i dont have time do to family
    selebrations
    but what cpu should i compare with then you think or is there a meshure
    of it here already
    Best regards
    MIS // TRH Logos // www.trhlogos.dk
    3D graphics, Anaglyph stereo, Digita & Macro photos & 61 Free Lightwave Video tutorials,
    wich adds up to more then 5 hours of Video.
  2. #152
    just did a test on the first smoke scene
    rendering on win xp on a Q6600 quadcore 2.4 clocked to 2.9
    in 9,6 it took 5 minutes 11 seconds
    in 10,1 it took 6 minutes 49 seconds
    so over a minute more for 10.1 sadly
    Best regards
  3. #153
    the robotreflection3 tests on my Q6600 clocked to 2.9 running xp
    Says
    Lightwave 9.6 55,7 seconds
    Lightwave 10.1 58 seconds
    Best regards
  4. #154
    Hopper 4.1 ghz for a Q6600 sounds like alot
    mine is currently running 2.91
    i take it your not running with standart cooling on it am i right ?
    what did you run when you did 3.8 ? was that standart cooling ?
    Best regards
  5. #155
    Super Member JonW's Avatar
    Jul 2007
    Sydney Australia
    2,235
    Smoke LW 64 bit W5580 (getting a bit long in the tooth now! A pair of X5690s would be nice!)
    9.6 1:45
    10.1 1:54
    11.0 1:54
    A bit slower, although unfortunate it's gone backwards, I would still rather have the new features.
    Procrastination, mankind's greatest labour saving device!
    W5580 x 2 24GB, Mac Mini, Spyder3Elite, Dulux 30gg 83/006 72/008 grey room,
    XeroxC2255, UPS EvolutionS 3kw+2xEXB
  6. #156
    Jul 2009
    Manchester UK
    186
    got to page 5 and decided without reading the rest I win for slowest render time of 19 mins 50 secs for avalanche scene, forum browesing and DL going at same time, gonna turn DL and browse off to see if it speeds up by 10 seconds or so. Machine specs as in sig.
    Edit - My dual channel may now be single channel as they werent match pair of ram sticks to start with and I changed the slots they were in some time back, didnt check to see if DC was on or off after last change will do now though.
    Edit 2 - Even though they werent matched pair of ram sticks DC still worked and registered at 667 mhz instead of 333 mhz once ram sticks were put in the correct slots for DC useage. Will be a while before i switch off DL though as its been creeping along at 50kps for last few days but today its at 300+kps, typical isn't it when I want to stop it it speeds up. DL is water margin old show from 70's
    Edit 3 - First render on LW11 btw rerendering now on LW10.1 seems faster already :/ will add to this edit speed on 10.1 when finished... 17 mins 49 secs in 10.1 so a little faster, 10.1 in discovery mode as dongle out to use LW11 in trial mode dunno if it makes a difference to render speed but will put dongle back in and rerun tests when DL finnished and post results to this post later tonight.
    PC - Win XP SP3 - Conroe E6600 intel @ stock 2.4ghz - 2 gig DC DDR2 @ 667mhz - GF GTS450 1 gig -
  7. #157
    9.6.1 on 4x Opteron 6272 2.1
ID:	102576   Click image for larger version.
    Cheers
    Tomek
    GarageFarm.NET
    The Cheapest Render Farm - 10,000 cores and growing!
    Skype: garage.farm
  8. #158
    Jul 2007
    Sydney Australia
    2,235
    I didn't think 9.6 did 64 threads?
    LW11 would be interesting?
  9. #159
    Quote Originally Posted by JonW View Post
    it does, i mean 9.6.1 does
    I will, just need some spare time.
    lw 10.1 smoke on 3930k overclocked to 4000Mhz 1:52.. will overclock futher
    Cheers
    Tomek
    GarageFarm.NET
    Skype: garage.farm
  10. #160
    Jul 2007
    Sydney Australia
    2,235
    I just tried this scene with HT off:
    Here are my benchmarks for LW11.0 1:54 (114) HT on, & 2:25 (145) HT off. (I haven't got around to updating LW11)
    So if you have a 60 minute render with HT off. It's only going to take 47 minutes with HT on. Obviously it's will vary a bit from render to render. Having HT off, is not the end of the world, & will help in other ways!
  11. #161
    Tests from our new render node, I am still making some tests but looks like we will move to this new machines.
    Ava_Test - 2:04 / 124.5
    rob-b2 - / 24.5
    If rest of the tests will go OK we will have 32 of them next month. It will be 10 cores per node only and super massive processor cache so most of your scenes should cost bit less per Ghz than on 12.
    Cheers
    Tomek
    GarageFarm.NET
    Skype: garage.farm
