Results 1 to 2 of 2
Thread: In-Point Nudging and Live Offset
    Jan 2010
    Sarnia, Ontario
    6
    In-Point nudging:
    If it was possible to use the SHIFT key with the -2,-1, +1,+2 to move the in-point of the selected clip forward or backwards it would be easier to do replays of the same play, but with different lengths
    Live Offset:
    Being able to have a drop down box to select how far in delay mode I want to run when I hit the LIVE key would be helpful. Right now, I am hitting LIVE then -2 and -1 to run 3 seconds behind. Being able to make that happen with one button press would streamline things and maybe be easier on the hardware.
    Dec 2007
    Germany
    173
    Quote Originally Posted by DanielGraig View Post
    In-Point nudging:
    If it was possible to use the SHIFT key with the -2,-1, +1,+2 to move the in-point of the selected clip forward or backwards it would be easier to do replays of the same play, but with different lengths.
    Yes, have the same wish:
    Maybe good to have "-8,-4, +4, +8" seconds moving when pressing the SHIFT key. And probably nice of this time could be edited in the (advanced) settings!
    Best regards,
    Matthias
