Results 1 to 2 of 2
Thread: How can I deform an object with fine control?
    I am working with LW 8.0
    I am trying to fit a purchased model of a human respiratory system into a human figure model that I exported from Poser. I've done most of the fiddly bits to get the organs to align where they belong. However, the last thing that I have to do is to deform the trachea and the esophagus to attach to the back of the throat.
    Here is the problem, because the models are organic, I need to twist and bend them along arbitrary axis with very fine control. None of the transform tools in Modeler seem to have fine enough control to do what I want to do. Using "Rotate on Arbitrary Axis" would be a great place to start, but it doesn’t have "Fall-off" controls. So,
    1) Can anybody suggest a way to invoke a very fine control of any of deformation tools?
    2) Any suggestions as to the best tool(s) to use to twist and bend the upper part of (what is essentially) a couple of cylinders to align with an existing attachment point?
    3) I tried using Bones initially, but without the desired results. I may try this again but if I do manage to deform the model as I like, CAN I EXPORT THE POSITION CREATED BY BONES INTO THE PERMANENT GEOMETRY OF THE MODEL?
    Thanks in advance for any suggestions.
    Terry
    7,897
    Quote Originally Posted by OcatilloPicture View Post
    Yes, you can. You have to use File > Save > Save Trans Object..
