I wanted to give you all a heads up that we will be giving away a prize from Maas Digital today, that’s right Dan at Maas Digital has donated an Unlimited Licenses of StarPro Starfeild Generator for today’s class.
StarPro Unlimited is a $249.00 value and works on the MAC or PC.
So if you have not registered yet, register now, not only will you learn award winning rendering and Lighting techniques. Now with a free copy of StarPro one lucky LightWave 3D user will be rendering astronomically correct star fields. Kelly’s classes have been amazing and today’s is sure to be no different. Register Now - https://www2.gotomeeting.com/register/308051938
NOTE: By registering, you will also receive a free download of the class when were done editing and preparing the training for public release. This is a 49.00 minimum value. Today’s class registration fee is 19.95.
So today not only could you learn some ground breaking, award winning effects, but you could also be rendering beautiful, astronomically correct star fields in LightWave 3D.
About StarPro:
I developed StarPro because I was frustrated with the traditional methods for rendering stars. Lightwave's point particles don't motion-blur properly and have aliasing problems even at high AA settings, while texture-based techniques are prone to blurriness issues.
StarPro uses an innovative rendering algorithm that draws realistic star fields with flawless anti-aliasing and motion blur in only seconds per frame. Stars will never be jaggy or flicker even under the most extreme camera motions. StarPro includes a NASA database of over
2 million stars so you can render the real night sky, and an optional randomized star field in case you don't want to see familiar constellations.
* Integrates seamlessly with LightWave 3D® scenes
* Star positions, brightness’s, and colors taken from a real star catalog
* Use the included NASA star databases, or create your own star fields
* Fully supports high-dynamic-range rendering (HDRI) with or without gamma encoding
* Resolution independent; suitable for web, TV, HD, and film
* Production-tested on Maas Digital's own animation projects
For more images or info, see http://www.maasdigital.com/starpro/
Register Now for Kelly’s class here - https://www2.gotomeeting.com/register/308051938
