Thread: Help me please
    www.digitalcrush.co.uk neilp's Avatar
    Newcastle England
    263
    Help me please
    Guru's
    I have a problem using FPrime and wondered if anyone knows a quick fix.
    Im rendering glass in a building that reflects trees, the trees are single polys mapped with jpegs in the colour chanel and transparency chanel. The trees that I see in the foreground render perfectly with their transparent backgrounds however the reflected trees in the glass have white backgrounds - Any ideas?
    Neil
    Jun 2005
    Reading UK
    3,136
    Instead of using transparency use clip maps - it will render quicker and should eliminate the dodgy reflections.
    i7 X3930/32GB/Quadro 4000
    Newcastle England
    263
    Clip maps - never used them before, can you briefly explain how please
    Neil
    Jun 2005
    Reading UK
    3,136
    Sure..
    Select the tree plane object and hit p to bring up the properties box. On the render tab you will see an option to use clip maps. Then use a black and white map to clip away the geometry at render time. White means clip all - Black is no clip.
    Newcastle England
    263
    Thanks steve
    Is this technique possible with two crossed polys for the tree to give it more dimension. If it is how would I do that? Once you have the clip set up do you then remove transparency?
    Neil
    Jun 2005
    Reading UK
    3,136
    In modeler, create your plane and create a UV map for it. Then duplicate and rotate into the cross position. Now if you apply the maps to the UV you created, it will stick to both planes. Yes delete the transparency maps after you have set things up.
    Quote Originally Posted by neilp View Post
    Sounds like the ray recursion is too low.
    Confirmed -
