Results 1 to 15 of 18
Thread: Nodes Help
    Murcia, Spain
    3,012
    Nodes Help
    Im getting my head around nodes. Ive come on quite well but ive saved nodes and put them in my preset shelf, now i cannot apply them to another object.
    Ive tried all the ways you used to do it for surface presets but when it come to nodes it just does not work.
    Im using 9.6.1, hope this is not the reason. How do i apply a node saved in the preset shelf to another object with nodes already applied, i want to delete 1 set of nodes and apply the preset shelf nodes.
    Any help.
    Regards John
    Dell XPS 15
    Intel i7 7700HQ 2.8GHz
    Windows 10 64Bit
    NVidia GeForce GTX 1050 Ti
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
    NewTek Developer jameswillmott's Avatar
    Dec 2004
    Gold Coast
    3,171
    You can copy and paste nodes from one surface to another, you have to select them all together and copy as one operation though, then hook them up in the new surface. What are you trying to do specifically?
    LightWave3D training, assets, news and discussion at www.liberty3d.com
    My opinions are my own and do not represent the opinions of any other entity, Liberty3D is not officially endorsed by NewTek.
    Murcia, Spain
    3,012
    Hi James, Ive saved the nodes as a node file and also in the preset shelf. I want to load another object and copy these nodes to the new object but all its doing is applying the final surface color not all the nodes, im sure ive done this before.
    I mean to stop lightwave and restart load in another object then apply these nodes to this object.
    Regards John
    Dell XPS 15
    Windows 10 64Bit
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
    Super Member warrenwc's Avatar
    Nov 2005
    Tulsa, Oklahoma U.S.A.
    903
    If you pull down the node editor's menu & select "Import Nodes", you should get a browser window to load your saved node files.
    Warren Christiansen
    Core i7 3.2Ghz
    12GB Ram
    Windows7 64
    Geoforce GTX285
    Murcia, Spain
    3,012
    Hi Warren, yes ive done that but when i import the node it only imports 1 node not the whole node tree.
    Dell XPS 15
    Windows 10 64Bit
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
    Nov 2005
    903
    Make sure to group select all the node you want saved & from the same menu select "export nodes" that should save your nodes file.
    Warren Christiansen
    Core i7 3.2Ghz
    12GB Ram
    Windows7 64
    Geoforce GTX285
    Dutch Bacon
    Dec 2007
    The Netherlands
    260
    uhm I think you can just save out a surface and then load it onto another object as well.
    Nov 2005
    903
    I thought so too, but the nodes don't transfer.
    Warren Christiansen
    Core i7 3.2Ghz
    12GB Ram
    Windows7 64
    Geoforce GTX285
    Really? They load fine for me; double-click the preset, viola, nodes - but I'm using 9.6. Are you using 9.6.1 warrenwc? That should be reported quickly.
    Confirmed -
    Nov 2005
    903
    Maybe it's a 64 bit thing but preset or save & load don't bring nodes along.
    Warren Christiansen
    Core i7 3.2Ghz
    12GB Ram
    Windows7 64
    Geoforce GTX285
    Murcia, Spain
    3,012
    Im on 9.6.1 and Win64. It definately does not work
    Dell XPS 15
    Windows 10 64Bit
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
    Might be a Windows thing, I'm on osx
    Confirmed -
    Nov 2005
    903
    Okay,
    If you're still with me, the workaround that I have found is to save an object with your surface( I just use a sphere, but if you already have the surface on an object make a note), then save the object with the surface name in an objects/surface directory.
    Then just load the object- copy & paste the surface & delete the object.
    Nodes WILL come across if you copy & paste a surface in the surface editor.
    It ain't pretty, but it works
    Warren Christiansen
    Core i7 3.2Ghz
    12GB Ram
    Windows7 64
    Geoforce GTX285
    Murcia, Spain
    3,012
    Hi Warren, yeah ive found a work around but im wondering if its a bug anyone know if this has been highlighted before on either 9.6.1. or HC
    Dell XPS 15
    Windows 10 64Bit
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
    Engineer/Entrepreneur Sekhar's Avatar
    Sep 2005
    Pasadena, CA
    2,124
    You're probably hitting the same bug that's in the "HC" version (can't give a link to thread here since that's the CORE stuff). That's been fogged, I guess they'll fix it in 9.6.1 when they fix HC, but I'd still fog it for 9.6.1.
