Thread: opengl render
    Feb 2009
    France
    23
    opengl render
    Is there a way to do hight resolution render with the opengl preview in layout, something like 6000x10000pixels(and save it)? How to do it in Lightwave? I have tried quickshade render and realistic render and opengl but the result is not the same, take a look
    i would like to use the opengl render as a final render.
ID:	79157   Click image for larger version.
ID:	79158   Click image for larger version.
    Mar 2004
    Northern New York
    5,254
    For opengl all you can do is a screen grab. If you want it high resolution then you will have to do a normal render using the F9 key. But before you do your render, select the camera (shift-C), open the camera properties (lowercase p) and set your resolution. Once you exit the camera properties then you can hit F9 to do a render and save from there.
    Washington State, USA
    2,880
    You can "Make Preview" then "Save Preview" but it is limited to your screen size.
    Mar 2004
    Northern New York
    5,254
    Quote Originally Posted by dwburman View Post
    Yep your right, I tend to forget about it since I only have used it twice in the last five years. Most of my normal renders are more than fast enough for what I have done.
