Thread: how do you make an object look like a ghost?
    Question how do you make an object look like a ghost?
    I have a character that I want to make a ghost. I want the edges to be opaque and get transparent in the middle. Anyone know what surface settings i should use to achieve this or any other ghostly look?
    Lurking Member brtk's Avatar
    Sweden
    94
    You could applay a gradient to the transparency channel...Set input parameter to incidence angle, make new gradient key at 90 deg and give it a value of 100%, key at 0 deg should have value 0% if you want to have edges opaque. You may want to add some more keys depending on what effect you want to achive.
    hope this helps
    /Bart
    Lightwave Pimp Skonk's Avatar
    Yorkshire UK
    1,454
    Make a gradient in the transparency channel and set it to Incedent Angle, and have it go from 100% trasp to 0%, play around with that and i think it should give u the opaque edges.
    I'll have a go myself to make sure my info aint bad
    James..
    uh wha?
    Yorkshire UK
    1,454
    Bah, beat me to it by less than 1 min
    uh wha?
    Sweden
    94
    He he, havent posted on foruns for cop of weeks so now Im posting as fast as I can.
    /Bart
    Gentleman Aegis's Avatar
    The Fortesque Mansion
    1,029
    Umm... how about using Edge Transparency? (Surface Editor/Shaders/Edge_Transparency)
    "Special power!"
    Andrew G. Morgan ~ CG Gunslinger
    Survivor Films Ltd.
    London, UK
    Click here to email me!
    Sweden
    94
    Yes... and how about Fast Fresnel shader Surface editor > Shaders
