Page 4 of 4 FirstFirst ... 234
Results 46 to 53 of 53
Thread: Script that renders all frames in a scene?
  1. #46
    Super Member Hieron's Avatar
    Aug 2006
    Netherlands
    1,685
    hehe.. RotfL had its revenge on me already..
  2. #47
    San Antonio, Texas, USA
    13,056
    Quote Originally Posted by Lightwolf View Post
    Here you go, another amazing plugin from db&w.
    We proudly present:
    Revenge of the Lenscap
    The image viewer that does nothing(tm).
    I've only got a Windows 32- and 64-bit version up at the moment.
    Cheers,
    Mike
    Gotta say, this must be your best work Mike!
    Nice though, you never know when it might come in handy!
    UI / UX Designer @ NewTek
  3. #48
    Aug 2006
    Netherlands
    1,685
    Hi Matt
    I get enclosed error pretty often... not sure why that would pop up. Do you have a clue or remedy?
  4. #49
    This usually comes up if your control identifier is (nil), which usually means that it's out of scope. Call it as a global variable and you'll be able to use it anywhere.
    If this isn't the problem then it's probably because the control id itself is invalid, or if your script is big it may be that LScript is losing the variables (it has happened to me on large scripts).
    To be sure, you can paste the code here for inspection.
  5. #50
    Malmö, SWEDEN
    7,694
    This is interresting...
    I have a situation right now where an F9 takes about 1 minute and 30 sec to render, while an F10 render will take about 12-16 minutes to render. Same thing with Screamernet. It doesn't make sense...
    Using this script ends up with the same redicilous rendertimes as I have with F10 or screamernet...
    Senior Technical Supervisor
    Cinematics Department
    Massive - A Ubisoft Studio
    Intel Core i7-4790K @ 4GHz
    16GB Ram
    GeForce GTX 1080 8GB
    Windows 10 Pro x64
  6. #51
    13,056
    Quote Originally Posted by Hieron View Post
    Hi Matt
    Ahhhhh, it's probably trying to set something on the UI without it being initialised.
    See if this works.
    Attached Files Attached Files
  7. #52
    Quote Originally Posted by Cageman View Post
    ...did you prepare the scene correct?
    ...did you make the Gi cache file read-only?
  8. #53
    great script. thx
    sb
