Results 1 to 15 of 15
Thread: does lscript support relative paths
    hello;
    I have an lscript that uses matchdirs(); I am on a winxp;
    currently I can only make it work using:
    matchdirs ( "C:\\a_dir\\sub_dir\\" , "*" ) ;
    I would rather use:
    matchdirs ( "..\\sub_dir\\" , "*" ) ;
    is there some syntax that lscript will permit for relative paths?
    thanks;
    Stuttgart, Germany
    13,605
    Quote Originally Posted by dsdsdsdsd View Post
    I would rather use:
    thanks;
    Have you tried:
    Code:
    matchdirs ( "sub_dir\\" , "*" ) ;
    That should work on a path relative to the current content directory.
    Cheers,
    Mike
    Mike, thanks for your response;
    I am trying to get to a directory that is above my current directory, so I will need some kind of .. syntax to get me up the directory hierarchy;
    thanks;
    parse or split the content path
    array = parse("//",contentdir)
    array = split(contentdir)
    then just ignore the last item in the array.
    http://walen.se my plugins
    walfridson, thanks for your response;
    I think what you are suggesting is slightly different than what I am working on ... I believe that you are suggesting a string-related function;
    but I am working on a file-management function, specifically using a relative file path within a file-management function;
    thanks though,
    Shannon
    Stuttgart, Germany
    13,605
    thanks though,
    Shannon
    But you can build an absolute path from that suggestion and then pass that to matchdirs.
    Cheers,
    Mike
    Code:
    	contpar = parse("\\",getdir("Content"));
    	newpath = "";
    	for(i=1;i<contpar.size();i++)
    		newpath += contpar[i] + "\\";
    	info(newpath);
    I suppose that if there exists a value for the getdir( "?" ) function that will return the location of the lscript itself, then I could use it;
    unfortunately getdir("Content") returns the location of my LW installation, as opposed to the location of the lscript that is running;
    I will look through the docs for something;
    thanks,
    Shannon
    SCRIPTID points to the path of the script thats running.
    info(SCRIPTID);
    yes it does ... how did you know about this ... I did not find it in the references: LscriptUserGuide.pdf, LScriptReference.pdf;
    thanks very much to you both,
    Shannon
    Use this, can't remember who created it but the old homepage for it gives 404
    I did find the SCRIPTID in this new document, although it is pretty obscure;
    but more importantly, this implies that Newtek is updating/improving their Lscript documentation, which will be a benefit to LW I believe;
    thanks,
    Shannon
    San Antonio, Texas, USA
    13,055
    The ONLY LScript resource you'll ever need!
    http://www.mikegreen.name/Lscript/Lscript%20Index.html
    very nice;
    Super Member Red_Oddity's Avatar
    A thousand years from here
    3,352
    Does
    Code:
    matchdirs ( "sub_dir\\.." , "*" ) ;
    work?
    I have no special talents. I am only passionately curious. - Albert Einstein
    visit my company site : House of Secrets
    visit my personal site : svenneve.com
