Thread: Record Pivot Rotation Question | Export to Game Engine
    Not to scale BlueApple's Avatar
    Nov 2005
    Los Estados Unidos
    1,026
    A friend of mine is trying to write an exporter to get the bones out of LightWave and is having trouble. Specifically, using Record Pivot Rotation zeroes out the bone's rotation and is making it so he can't determine the bone's orientation.
    Does LightWave store the original orientation of the bone prior to using Record Pivot Rotation? Is there an easy way to recover this information?
    Any help is appreciated.
    Adam Martin
    my portfolio
    Mac Pro 2x3Ghz Dual-Core Intel | 8 Gb RAM | OS 10.6.8 | ATI Radeon X1900 XT
    Nov 2005
    Los Estados Unidos
    1,026
    Apologies, but I had intended to place this in the General Support forum
    Adam Martin
    my portfolio
    Code Muppet evenflcw's Avatar
    Stockholm, Sweden
    2,642
    I'm not sure but it seems like it should be a simple fix. The pivot basically just defines a static offset. It can be read an thus subtracted from each keyframed value. Although I would think it might throw off some expressions and similar if they are used in such a way that they are dependent on where the channels zeroes out. BUt I figure everything is keyed/baked for export?
    Easiest way to see what happens is just to save two scenes, one RPR'ed and one not, and compare. From the looks of it, if you RPR, all keyframed motion values are offset by the recorded value (ie NOT "stored with original rotation before rpr"). The internals that you get when accessing the motion data through SDK/LS could be different from what's in the LWS, but that would be unlikely (and annoying). But do compare (once).
    PS. Personally I would have posted in the developer section. We get so few posts we shiver with excitement everytime there is a new one.
    Nov 2005
    Los Estados Unidos
    1,026
    Thanks for your reply. My friend and I will check this out in the morning.
    Quote Originally Posted by evenflcw View Post
    Future inquiries will be posted there, despite the threat of excitement induced mass shivering
    Adam Martin
    my portfolio
