Follow us on Facebook Follow us on Twitter Flickr Watch us on YouTube
Register
Results 1 to 8 of 8
    #include command not working
    I did not use Aura for a long while. Yesterday, I use aura George script for some operation and found that #INCLUDE command is not working. Aura just show me a error message indicated the line with #include. All the old scripts with #include command got the same result.
    I am using VT[5.2] (Aura-VT 2.7 US).
    Chen Pan
    AnimLab, Taiwan
    http://www.animlab.com
    animlab at ms1 dot hinet dot net
    14,107
    Hmmm. I just tested the same version, by adding a print statement to one of the default includes. It worked ok. I'm not sure what to attribute your problem to. The exact placement of an include call can be fussy, but I don't know why you'd be getting an error for a script that has previously worked.
    Have you tried invoking the include with an explicit path?
    Yes. I test it with full path name. Still get the same error message. If your system is fine with "include" command, then it might be my VT system problem. It have been added with so many things since I have to test anythng for my clients.
    I might try reinstall my VT[5.2] but it will not happen in this week.
    Thank you for the reply.
    Chen Pan
    AnimLab, Taiwan
    14,107
    You're very welcome, Chen. I'm happy to be able to do something for a person who has been such a big help to many here.
    I have had the same problem as I load a script in George - Bin menu.
    No script in the George - All menu works.
    But as I load a standart script, for exampel Center in the Bin menu,
    it works without error and in All menu again too.
    Roland
    14,107
    I wonder ... are you by any chance running Vista, or Win7?
    I have reinstall my VT4 and VT5 and now both version of AuraVT run without problem.
    I still not sure what cause "#include" command failed but I suspect that the (#include) search path of Aura have been miss placed to some where.
    Chen Pan
    AnimLab, Taiwan
    14,107
    Include statements often refer to relative paths. This can fail if defaults.grg is missing or messed up.
    The reason I asked about Vista is because, as you may know, it interferes with attempts to manually write files to Program Files(x86). Weird things can happen if you edit scripts at all (a proxy file is written somewhere else on the system, and pretends to be in the correct location.
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright 2000-2012, NewTek
vBulletin Skin By: PurevB.com
