Results 1 to 2 of 2
Thread: HD Camera
    NYC
    3,248
    HD Camera
    A simple low res 16x9 LiveSet (well the HD camera is low res no the set)
    http://www.burgos-family.com/liveset/HDCamera.zip
    Copy to your VSFX folder and use in VT[5].
    The camera LCD is fed from the effects bus and there is a key input infront of the camera where a person can walk and talk in front of it.
    The key is to the left side of the set covering up to the end of the LCD on the camera.
    Just a simple experiment,
Name:	HD Camera.png
    Jose Burgos
    NewTek Certified Trainer
    www.burgosfx.com
    FaceBook
    Twitter @NYTriCaster
    that's way cool!! we should do one wit a broadcast camera that you see in a news room, which should be easy enough with your setup not to mention using the LiveSet Constructor.
    Tony
