Results 1 to 12 of 12
Thread: how to make a credit card hologram effect
    lebanon
    125
    hi guys,
    how do i make this hologram effect that you get on some credit cards for genuity...thanks,
    In the zip-file is a node-setup for a hologram effect. You will need 2 different images (i didn't include my images because of the size).
    greetings
    Martin
    Attached Files Attached Files
    lebanon
    125
    wow great martin thanks, i will try it out now
    thanks alot
    Mar 2007
    UK
    688
    See this http://www.spinquad.com/forums/showt...light=hologram
    Files attached
    you need to save the movie as .mov
    state of confusion
    6,973
    I can't see it either
    Skype...lost_in_3d_space
    Sager
    I7-4800 OC'd to 3.3 GHz
    12G 1600mhz mem
    256 gigs raided SSD drive
    Jim, that's nice! Merci.
    Model: MacBook Pro 10.6.4 - 2.66 GHz - 4GB - NVD GF GT 330M
    Render: Win7 64 - Core 2 Quad Q9550 2.83GHz - 8GB
    Mar 2007
    UK
    688
    "I can't see it either"
    Sorry, dunno why it does that...
    RMB, Save as, then change extension to MOV as previously stated....
    Wierd.
    May 2009
    Australia
    7
    Good work.
    The only problem with the samples though is they don't show the parallax that you get in the real thing. Also the repetitive text would usually sit behind the subject.
    Armed with the knowledge I've gained from this thread and the spinquad one, I reckon the way to go is the CCTV shader. The holo camera should be pointing at the subject with a background surface behind it holding the repeating text. When the main camera moves across the surface the CCTV is sending to, the holo cam should move slightly too, in sync with the main cam to simulate the parallax effect.
    Thanks for all the good work. You guys are awesome, I should have come here weeks ago.
    May 2009
    Australia
    7
    I just tried it out, to get the parallax effect you don't actually need to move the "holocam". You just select "holo" type in the shader, then as you move the main cam you automagically see around the sides of the holo object
    Only issue I'm having is that no matter what I do to the distance of the holo object to the holo cam, change the scale or whatever, it always stays the same, and squashed from left to right. Weird.
    Airwolf 3D man virtualcomposer's Avatar
    Jul 2008
    Castle Rock, CO
    1,440
    I am using the mac version of LW and was wondering where I put the Hologram Node? I can't seem to find the file folder where the rest of my nodes are.
    Graphic Designer & 3D Textures
    -Mac Pro 2.26GHz | 8-core | 3TB HD | 12GB RAM | Dell Ultrasharp 2707 | ATI Radeon HD 5770
    Jul 2008
    Castle Rock, CO
    1,440
    Quote Originally Posted by kruemel_1 View Post
    greetings
    Martin
    Can you show us the settings in your nodes configurations? Or a tutorial?
