Follow us on Facebook Follow us on Twitter Flickr Watch us on YouTube
Register
Page 1 of 3 123 LastLast
Results 1 to 15 of 38
    Dec 2002
    San Antonio, TX
    3,830
    Do I need a VT PRO card to run VT[5]?
    There have been numerous questions about the uses of LiveSet(TM) in VT[5] and whether customers using the older VT33 card can utilize these live effects.
    Here is a PDF file that outlines the basics of what is possible.
    Attached Files Attached Files
    Don't stream it - TriCast it!
    XDCAM HD production ScorpioProd's Avatar
    Albany, NY
    4,346
    Paul, what if one wants to do one of the most common type of things, going from a live anchor desk with a live PIP, cutting to that SAME live PIP but using just the pure input full screen. A simple cut like that should work with the old VT card, correct?
    Eugene
    Scorpio Productions
    Registered User Cineman's Avatar
    Huntsville, AL
    400
    Re: Do I need a VT-PRO Card to use VT[5] ?
    Think I would be remiss to not mention at this point that Bobs 3rd Channel, Plug-In, can do all of the situations pictured, as tested on VT[3] and VT[4], without the VT-PRO Card. And it can do it with a cut or dissolve to, or from, one of these sources, glitch free. You can use use the Preview bus to see the live source that you want to come up next, or just return to Main.
    One super capability of 3rd Channel is that you could add a second display screen to the left pictures, or a 3rd window/box to the right, and display three live camera shots with the PRO card, or two with a computer generated source in the third, without it.
    Nes Gurley
    The Best You'll Ever See! KHS-TV's Avatar
    Jan 2005
    Kingston, NY
    165
    Quote Originally Posted by ScorpioProd
    Certainly looks like it based on that PDF.
    Technical note: In practice, a non VT-PRO card will allow you to set up an effect that uses two live video sources, however
    it will then “glitch” when you transition or switch to a third. You would also not be able to use the preview bus to see any
    the live source that you want to come up next.
    Since with your scenario you're never switching to a third, it shouldn't glitch, right?
    NewTek Specialist Adam_LightPlay's Avatar
    Studio City, CA
    199
    Thanks Paul.
    Is the info in the .PDF the same whether you are using an SX-8 or an SX-84? Or when you say VT-Pro can do such-and-such, are you also assuming the user is using an SX-84?
    Thanks for a clarification.
    Adam Lightplay
    LightPlay Productions
    "The future's so bright, I think it's unterminated".
    The card is the key part, it has the 2 or 3 chips on it, but you will need a breakout box of some kind for any switching.
    John Perkins
    Software Engineer
    "No, it's my natural color..."
    Jan 2004
    Sol III
    126
    Besides the awesome over-kill of the SX-84, are there smaller breakout boxes available? I myself could probably get by comfortably with only three hardware inputs for switching, although if no one made a box that small, 6-8 hardware inputs would also get consideration.
    3,452
    Quote Originally Posted by Thalek
    I fill up all 8 inputs on my SX84 constantly. Of course I use component connections. Soon SDI.
    Jef Kethley
    PIZAZZ
    I make stuff work....www.pizazz.com
    Gear Used:
    TriCaster: All + 3Play 820 & 425
    Cams: Panasonic HPX370
    Cabling: Tac2 Fiber/ATEM convertors
    Jan 2004
    Sol III
    126
    At least for the near future, I'm likely to be using composite inputs. I've used a single Firewire input, but there's about a one second delay for the encoding, transmission, decoding, and it is somewhat disorienting. Especially to our talent, who have a monitor so they can see where they are with respect to the "virtual" set.
    Being essentially a hobbyist, my needs are more modest than you professional guys. [grin]
    Jul 2004
    north logan
    296
    double screen
    so to do the double screen sources, does it require a SX84 BOB? or can you do it with the SX8?
    Jan 2005
    Kingston, NY
    165
    Quote Originally Posted by lvsoule
    You can use an SX-8. In fact, you can use all VT[2] hardware to do double-box. If you use the VT[2] card, though, just make sure you don't accidentally try to use three live sources at one time on the Switcher - the driver will silently crash and you won't be able to switch to anything anymore.
    Anyways, if you've got a VT Pro card, I believe you can still stream three sources in from an SX-8, so you shouldn't have that limitation.
    Jul 2004
    north logan
    296
    double box
    yeah we were able to do this once using the picture and picture transition, but it wasn't exactly what I was looking for. If you have a better way. I have a VT3 and a VT4.6 that was recently upgraded to the VT5
    I take my VT with 2 lumps JReble's Avatar
    681
    This is probably a great opportunity to nag Newtek again for an external 3 component/composite/Y-C input break out box like the Tricaster has. I'm really at a loss as to why they don't just put that in a box and sell it.
    Dec 2002
    San Antonio, TX
    3,830
    Quote Originally Posted by JReble
    NewTek initially thought that 3 inputs was the magic number, but not so, according to many prospective buyers. Note how TriCaster STUDIO has 6 inputs instead of 3.
    Since you brought it up, though, what would you be willing to pay for such a breakout? Hmm?
    up to $800
    If its free then it wont cost anything, right?
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright 2000-2012, NewTek
vBulletin Skin By: PurevB.com
