Follow us on Facebook Follow us on Twitter Flickr Watch us on YouTube
Register
Page 1 of 3 123 LastLast
Results 1 to 15 of 41
    The Real Homestar. Intuition's Avatar
    Venice, CA
    2,627
    My testament to Edge Modeling...and more.
    I will post renders here that I did in Lightwave 9 while using the beta.
    This first is a series of Pictures from my modeling tests as soon as edge modeling become available.
    The skull was drawn from a profile picture with edges and then extend was used to pull the geometry out and sculpt it to shape. Similar to smooth shift but I was creating 3d form from 2d lines. This process is similar to the way many hexagon nurb tutorials work. It was a fast session. About 4 hours from scratch to final renders. The texture is the side view picture I found on the internet but it is using the oren Nayer shader mixed with Phong spec shader.
    Rendered with BG radiosity Low AA.
    I will post more test in this thread soon. I have some Omega Shader SSS tests with a Buddha model that is casting caustic refraction on the floor behind it.
ID:	35493   Click image for larger version.
ID:	35494   Click image for larger version.
ID:	35495   Click image for larger version.
    KC
    i loveeeeeeee that .... i loveeeee that.... again i loveeeeeee that
    i want more .... so please cancel your sunday rest off and show me some more
    new web page up www.null.hr
    Beautiful Bird-skulls. Can you show us some wires.
    I'm intrigued by your modeling method here. Any links to the tutorials you mention?
    "We've gone on holiday by mistake"
    Super Member Earl's Avatar
    Beaverton, Oregon
    1,231
    Excellent modeling! I'll have to give that technique a try.
    How Old? Really? Aww Heck colkai's Avatar
    St Helens, England
    7,688
    Aww man that's cool.
    If you ever feel like doing a tutorial on that let me know. I'd love to be able to create some raptor skulls.
    Gentleshaw Wildlife Centre
    ______________________
    Want to learn to model?
    'Nuff said.
    Registered User Werner's Avatar
    Johannesburg, South Africa
    405
    Quote Originally Posted by Intuition
    I will post renders here that I did in Lightwave 9 while using the beta...
    ...I will post more test in this thread soon. I have some Omega Shader SSS tests with a Buddha model that is casting caustic refraction on the floor behind it.
    Awesome model. I like the texturing as well.
    When can we see the other test renders you spoke about?
    Yup! It's very attractive. How many time did you spend to make it!?
    Gianandrea aka LAV aka gigionaz'
    the ever changing collage of our avatars
    my site
    LW is the zen way to 3D
    Foot in mouth wacom's Avatar
    May 2003
    Portland, OR
    1,904
    Really cool. Thanks. Can we see a wire frame?
    Venice, CA
    2,627
    Oh, hey guys.
    I got busy on another project at home seperate from Eden.
    Most of my time has been spent finishing that up.
    Here is a wireframe of the bird's top skull. Do you want the nurbed wires or would you like to see the cage before nurbing.
    The tutorial I was referring to is at the nurb modeling website Subdiviison modeling dot com.
    http://www.subdivisionmodeling.com/
    There is a tutorial there done in Hexagon on how to create a humanoid. I followed that tutorial but tried to use Lw9 edge modling instead. It worked well and I transferred that concept to creating the bird skull in 9.
    Since I've been busy I'll show you the logo I was working on.
    The zip file contains the logo. I designed both the 2d logo and 3d animation of it. The company was originally the same company I did the Mars project with - www.themarsunderground.com - but have changed thier name due to a split between management. So the new company is called Radius productions.
    I rendered it in Lw9 but used trapcode starglow for the highlights.
    It was a simple radiosity scene completely lit by GI with a simple reflection node setup on the ring with very slight refl blurring. The text is also refl blurred as well. Nothing too complicated. Simple and discreet like all my designs are. . I did the chior sounds with a program I use for music production called Reason. I use it with Protools 7 sometimes.
    When I finish the current project I'll post some of the SSS Buddha shots I have that are not just tests. I've been tweaking the caustic so its more real. Takes time though.
    Here is a test of the Buddha at low quality. I was tweaking the mm penetration setting to get the right scatter effect. I pluged the node into the refraction shading so I could get the caustic on the ground behind it. Please don't be too harsh about crit on the Buddha its a test only with no GI.
    More Lw9
    KC
    May 2003
    Portland, OR
    1,904
    Thanks for the posts- I'll be sure to check out those modeling tutorials too!
    Registered User darkChief's Avatar
    Mar 2006
    Vermont/Zambia
    143
    sweet sss. Nice skull
    Registered User newtekker04's Avatar
    Sep 2003
    Alberta, Canada
    127
    Wow, awesome work! Just out off curiosity, what's that XP theme you're using?
    Venice, CA
    2,627
    OK, Sorry bout the wait. Still more modification to come.
    Here is the Buddha with proper SSS settings rendered with GI.
    Now with a nicer render here for the meantime I can continue tweaking it
    Sorry, I was embarassed by leaving only the test render to see
    Oh btw the operating systemis called Stealth OS. Its a nice grey tone so my eyes don't go blind from staring at bright whites and greys all day.
    KC
    Particle in 3-D space.
    Sep 2003
    Sweden
    909
    Oh...love that Buddha!
    Great work
    Vista Home Premium Service pack 1
    Albatron GF8800GTS 640MB
    Intel Core 2 Duo E6600 2,4GHz
    Samsung HD321KJ 300GB
    Asus P5B i965P
    2 1024MB DDR2 PC2-4200 533MHz
    Still learnin' da wave! Steve Reeves's Avatar
    Oct 2003
    Norfolk, UK
    269
    Hey Intuition, love that Windows Theme you've got going on there.
    Is it a free one I can grab somewhere - thanks.
    SteveR
    www.srgrafix.net
    "...not bad for a man in pyjamas...very Arthur Dent..."
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Copyright 2000-2012, NewTek
vBulletin Skin By: PurevB.com
